Publishing
Guest
Jan 04, 2007 Jan 04, 2007
I am working with an online manual using individual topics. I have a Welcome Page which displays all the individual topics for one to click on to see a particular manual. I use the same page everytime for each release of the manual. I have a manual that is currently listed on the welcome page and I need to delete that reference and add the new reference. Same project just a different version. I thought changing the project name I would be able to generate and republish. However, when I do this, the link online displays Page not found. What am I doing wrong? Thanks.
586
Are these "manuals" topics that are within the same project? If not, what and where are they?
Guest
Several different individual projects. All of these project names have a place holder on the Welcome Page. For instance..
User Manual I Reports Miscellaneous Manuals
Demand Deposits 100s Rpts 7.8 Release Manual
Loans 200s Rpts Security Manual
Safe Deposit Box 300s Rpts
The Demand Deposits, Loans, etc. are individual projects. There is a 'link' to the manuals on the server to display on the intranet. The 7.8 Release Manual has changed since there is a new version, 8.0.
I hope this makes sense. Thanks for your help.
Guest
Sorry, the table did not come over correctly.
User Manual I
Demand Deposits
Loans
Safe Deposit Box
Reports
100s Rpts
200s Rpts
300s Rpts
7.8 Release Manual
Security Manual
Guest
I almost forgot an important factor. The Welcome page is in a project of its own called the Welcome Project.
OK so you have links in one project that point to other projects that are not part of a proper merge.
Then you updated one of the targets but did not change the filename of the start page of that target output. What you did do was change the text of the link but not the target. Correct so far?
If so, you must have changed something in the link itself. Have you looked at the true code in the Welcome project to see if that is correct? Have you checked that in the output file to make sure it is not being altered?
Guest
Jan 05, 2007 Jan 05, 2007
I did the changes in true code. From my understanding as long as the project was generated in any folder, all I needed to do was make the change to reflect the name of the new project. When I generated and publish, I have checked the path and it changes from _____ /Robo/BIN/Robo.dll?tpc=%2Frobo%2Fprojects%2F7_8_release_manual ___ to________ /Robo/BIN/Robo.dll?tpc=%2Frobo%2Fprojects%2F_launch 2FDoc2_home.htm&mgr=agm&project=8_0_Release_Manual -------*The lines and dashes preceeding and proceeding are not there, I had to put them in to keep everything from coming togehter.
You've lost me.
It's difficult to decipher that, try some paragraphs.
But what's all this /robo/bin/robo.dll stuff?
If what you are trying to show is the old and the new link, then the two seem very different. Can you make it clearer please?
Guest
True code is
<p><b style="font-weight: bold;">Miscellaneous Manuals</b><a href=" http://fjajdfjdlfjsa.com/roboapi.asp?project=7_8_Release_Manual"><br>
7.0 Release Manual</a><a
The only thing I did was change the 7_8 to 8_0
Guest
Currently online (intranet) when I select 7.8 Release manual and it displays, in the path this is displaying
http://documentation.company.com/Robo/BIN/Robo.dll?tpc=%2Frobo%2Fprojects%2Fversion_7_8_release_manu...
The 8.0 release project is separate and has been generated. On the Welcome project I change the 7.8 to 8.0. When I generate the Welcome project and publish and click on the link, this displays
http://documentation.company.com/Robo/BIN/Robo.dll?tpc=%2Frobo%2Fprojects%2F_launch%2FDoc2_home.htm&...
The last few posts have confused the issue. Your problem started out as you pointing from one project to another where just changing the path should have worked as you expected. But in your penultimate post there is reference to ASP which is not a method I am familiar with and then the paths contain references to a DLL which would not normally be in any call.
You are clearly doing something in a very non standard way.
I suspect that if ASP is involved, something else needs changing. The two links in your last past contain more differences that just 7.8 changing to 8.0.
I would be using an ordinary hyperlink and there you would just need to change the path and filename as required to reflect the new project.
Hi all
Peter: I don't believe it's a nonstandard way. More likely, FRUSTRATED!! is using RoboEngine and that's what is throwing the monkey wrench into the works. I personally have only very limited experience with this, so hopefully fellow Community Expert John Daigle will see this and chime in. The robo/bin/robo.dll stuff is all RoboEngine related.
Wishing I had more to offer to help... Rick
Guest
Thanks. Someone in another dept set up the Welcome and I got a crash course on it and RH. Sometimes the notes do not cover those little pesky things that go wrong.
Thanks Rick. I hadn't considered WebHelp Pro as the poster hadn't mentioned it.
RoboHelp Documentation
Download Adobe RoboHelp
