This is so squirrely ... as the page returns fast unless I
have debug enabled. After a few minutes with debug enabled, the
page returns and all of the 'times' are fast. I'm not sure why CF
is struggling on this page. I'll try to add the code above and see
what happens. But here is the debug output, when the page finally
returns and it looks like I have a good fast page.
Execution Time
Total Time Avg Time Count Template
734 ms 734 ms 1 C:\Inetpub\wwwroot\AccValid\SauAR.cfm
578 ms 289 ms 2
C:\Inetpub\wwwroot\AccValid\SauAR_ss_acc_valid.cfm
221 ms 7 ms 32 C:\Inetpub\wwwroot\AccValid\CCFormatDate.cfm
94 ms 47 ms 2
C:\Inetpub\wwwroot\AccValid\SauAR_SS_ACC_VALIDSearch.cfm
47 ms 8 ms 6 C:\Inetpub\wwwroot\AccValid\CCGetQueryString.cfm
31 ms 31 ms 1 C:\Inetpub\wwwroot\AccValid\CCExecuteSQL.cfm
31 ms 31 ms 1 C:\Inetpub\wwwroot\AccValid\CCOpenRS.cfm
31 ms 3 ms 11 C:\Inetpub\wwwroot\AccValid\CCWhereParams.cfm
31 ms 31 ms 1 C:\Inetpub\wwwroot\AccValid\Common.cfm
16 ms 8 ms 2 C:\Inetpub\wwwroot\AccValid\AccValidHeader.cfm
16 ms 8 ms 2 C:\Inetpub\wwwroot\AccValid\CCDLookUp.cfm
16 ms 16 ms 1 C:\Inetpub\wwwroot\AccValid\CCToSQL.cfm
0 ms 0 ms 5 C:\Inetpub\wwwroot\AccValid\CCAddParam.cfm
0 ms 0 ms 4 C:\Inetpub\wwwroot\AccValid\CCGetParam.cfm
0 ms 0 ms 2 C:\Inetpub\wwwroot\AccValid\CCParseDate.cfm
0 ms 0 ms 13 C:\Inetpub\wwwroot\AccValid\CommonConst.cfm
0 ms 0 ms 2 CFC[ C:\Inetpub\wwwroot\AccValid\CCSLocales.cfc |
GetText(CCS_LocaleID) ] from
0 ms STARTUP, PARSING, COMPILING, LOADING, & SHUTDOWN
734 ms TOTAL EXECUTION TIME
red = over 250 ms average execution time
SQL Queries
queryExec (Datasource=connSSDSP, Time=0ms, Records=0) in
C:\Inetpub\wwwroot\AccValid\CCExecuteSQL.cfm @ 17:14:31.031
ALTER SESSION SET NLS_DATE_FORMAT = 'MM/DD/YYYY HH24:MI:SS'
queryDlookUp (Datasource=connSSDSP, Time=16ms, Records=1) in
C:\Inetpub\wwwroot\AccValid\CCDLookUp.cfm @ 17:14:31.031
select rtrim(upper(GLOBAL_NAME)) AS RES from GLOBAL_NAME
where 1=1
queryDlookUp (Datasource=connSSDSP, Time=0ms, Records=1) in
select rtrim(upper(description_short)) AS RES from
ss_coded_list_values where type='ACC_VALID' and code='SID_PROD' and
obsolete = 'N'
queryS_RUN_NUM (Datasource=connSSDSP, Time=15ms, Records=1)
in C:\Inetpub\wwwroot\AccValid\SauAR_SS_ACC_VALIDSearch.cfm @
17:14:31.031
SELECT distinct RUN_NUM, max(generated_date) GenDate
FROM SS_ACC_VALID
Where run_num is not null
group by run_num ORDER BY run_num desc
CALLER.queryss_acc_valid (Datasource=connSSDSP, Time=31ms,
Records=14) in C:\Inetpub\wwwroot\AccValid\CCOpenRS.cfm @
17:14:31.031
SELECT P.ID_TYPE AS P_ID_TYPE, P.PERSON_ID AS P_PERSON_ID,
P.CNTL_NO AS P_CNTL_NO, P.NAME_LAST AS P_NAME_LAST, P.NAME_MIDDLE
AS P_NAME_MIDDLE,
P.NAME_FIRST AS P_NAME_FIRST, ACC_VALID_GEN_NBR,
SS_ACC_VALID.PERSON_GEN_NBR AS PERSON_GEN_NBR,
SS_ACC_VALID.ACCESS_REQ_GEN_NBR AS ACCESS_REQ_GEN_NBR,
GENERATED_DATE, SUBMITTED_BY, SUBMITTED_DATE, COMMENTS,
NEWACCREQ, AR_XFER_LUB, AR_XFER_LUD, RUN_NUM, AR.PERSON_ID AS
AR_PERSON_ID,
AR.NAME_LAST AS AR_NAME_LAST, AR.NAME_MIDDLE AS
AR_NAME_MIDDLE, AR.NAME_FIRST AS AR_NAME_FIRST, NEWAR.PERSON_ID AS
NEWAR_PERSON_ID,
NEWAR.NAME_LAST AS NEWAR_NAME_LAST, NEWAR.NAME_FIRST AS
NEWAR_NAME_FIRST, NEWAR.NAME_MIDDLE AS NEWAR_NAME_MIDDLE
FROM ss_acc_valid,
SS_PERSONS p,
SS_PERSONS ar,
SS_PERSONS newar WHERE
( (SS_ACC_VALID.PERSON_GEN_NBR = P.PERSON_GEN_NBR) AND
(SS_ACC_VALID.ACCESS_REQ_GEN_NBR = AR.PERSON_GEN_NBR) AND
(SS_ACC_VALID.NEWACCREQ = NEWAR.PERSON_GEN_NBR) ) AND
SS_ACC_VALID.RUN_NUM = 130946 And (ss_acc_valid.newaccreq IS NOT
NULL)
Scope Variables
CGI Variables:
AUTH_PASSWORD=
AUTH_TYPE=
AUTH_USER=
CERT_COOKIE=
CERT_FLAGS=
CERT_ISSUER=
CERT_KEYSIZE=
CERT_SECRETKEYSIZE=
CERT_SERIALNUMBER=
CERT_SERVER_ISSUER=
CERT_SERVER_SUBJECT=
CERT_SUBJECT=
CF_TEMPLATE_PATH=C:\Inetpub\wwwroot\AccValid\SauAR.cfm
CONTENT_LENGTH=
CONTENT_TYPE=
CONTEXT_PATH=
GATEWAY_INTERFACE=CGI/1.1
HTTPS=off
HTTPS_KEYSIZE=
HTTPS_SECRETKEYSIZE=
HTTPS_SERVER_ISSUER=
HTTPS_SERVER_SUBJECT=
HTTP_ACCEPT=image/gif, image/x-xbitmap, image/jpeg,
image/pjpeg, application/vnd.ms-excel,
application/vnd.ms-powerpoint, application/msword,
application/x-shockwave-flash, */*
HTTP_ACCEPT_ENCODING=gzip, deflate
HTTP_ACCEPT_LANGUAGE=en-us
HTTP_CONNECTION=Keep-Alive
HTTP_COOKIE=CFID=14; CFTOKEN=33114963;
JSESSIONID=ba30b9597906$F5V$A8$
HTTP_HOST=localhost
HTTP_REFERER=http://localhost/accvalid/SauAR.cfm
HTTP_USER_AGENT=Mozilla/4.0 (compatible; MSIE 6.0; Windows NT
5.1; SV1; .NET CLR 1.1.4322)
PATH_INFO=/accvalid/SauAR.cfm
PATH_TRANSLATED=C:\Inetpub\wwwroot\AccValid\SauAR.cfm
QUERY_STRING=S_RUN_NUM=130946&S_PERSON_ID=&S_ACCESS_REQ_GEN_NBR=&S_SUBMITTED_BY=&S_COMMENTS=&S_NEWACCREQ=&S_AR_XFER_LUB=&S_AR_XFER_LUD=&SS_ACC_VALIDPAGESIZE=%20&CFID=14&CFTOKEN=33114963
REMOTE_ADDR=127.0.0.1
REMOTE_HOST=127.0.0.1
REMOTE_USER=
REQUEST_METHOD=GET
SCRIPT_NAME=/accvalid/SauAR.cfm
SERVER_NAME=localhost
SERVER_PORT=80
SERVER_PORT_SECURE=0
SERVER_PROTOCOL=HTTP/1.1
SERVER_SOFTWARE=Microsoft-IIS/5.1
WEB_SERVER_API=
Cookie Variables:
CFID=14
CFTOKEN=33114963
Session Variables:
cfid=14
cftoken=33114963
sessionid=C_INETPUB_WWWROOT_ACCVALID_14_33114963
urltoken=CFID=14&CFTOKEN=33114963
URL Parameters:
CFID=14
CFTOKEN=33114963
S_AR_XFER_LUB=
S_AR_XFER_LUD=
S_COMMENTS=
S_NEWACCREQ=
S_PERSON_ID=
S_RUN_NUM=130946
S_SUBMITTED_BY=
Debug Rendering Time: 250 ms
