Opened a project. Changed branding to custom. Specifice just a starting branding element. Published, closed, went to EOJ.
Opened a different project. Can't change branding to end--all check boxes grayed. Can't specify a new custom branding theme. Can select standard branding but it still only shows up in the beginning, can't change to end (or background).Also, now it only uses the custom branding I created and used for the beginning of the other project.
Is there a cache that must be cleared?
Thanks. --Michael
Hi MichaelD443,
I followed your steps:-
opened a project
changed branding to custom
specified a starting branding video
published
clicked on close project button
opened a new project.
goto themes.
Can select any default themes or change the starting/end video.
In my case the themes dropdown is enabled and is working fine on my system.
Are the steps same as yours?
If the steps are same, then it's a system specific issue.
You can send us(vikrakum@adobe.com) the diagnostic log with steps mentioned to reproduce the issue.
There is workaround to get ride of your issue. Close Video Creator. Delete preferences.xml file from this location -> C:\Users\<username>\AppData\Local\Adobe\Presenter Video Creator 8.1\ . Open VC
Vikram
Adobe Presenter Engg. Team
