I have some code I created in Word VBA to combine several separate PDFs into a single PDF. The code works fine with the Adobe Acrobat 9.0 Type Library and Adobe Reader 9.0 installed.
But, with the Adobe Acrobat 10 Type Library and Adobe Reader 10 installed, the code fails at the marked code below. Any suggestions??
Dim acrobatApp As Acrobat.acroApp
Set acrobatApp = CreateObject("AcroExch.App")
Dim mainPDF As Acrobat.AcroPDDoc
Set mainPDF = CreateObject("AcroExch.PDDoc") ****THIS IS WHERE THE CODE STOPS WITH A "TYPE MISMATCH" ERROR****
Dim nextPage As Acrobat.AcroPDDoc
Set nextPage = CreateObject("AcroExch.PDDoc")
Dim numPages As Integer
'Loop through all selected VLS, and add each one to the end of the main PDF
For i = 0 To lstSelected.ListCount - 1
mainPDF.Open CurDir & "\" & Replace(ThisDocument.Name, ".doc", "") & ".pdf"
numPages = mainPDF.GetNumPages
nextPage.Open lstSelected.List(i)
If mainPDF.InsertPages(numPages - 1, nextPage, 0, nextPage.GetNumPages, True) = False Then
MsgBox "Cannot insert pages"
End If
If mainPDF.Save(PDSaveFull, CurDir & "\" & Replace(ThisDocument.Name, ".doc", "") & ".pdf") = False Then
MsgBox "Cannot save"
End If
'MsgBox lstSelected.List(i)
nextPage.Close
Next i
I doubt that this ever worked with Reader 9. You are using an interface
that is only available when you have Adobe Acrobat installed. There are
some features in the IAC (Interapplication Communication) API, but it's
very limited. The documentation will tell you what's available what what's
not.
Karl Heinz Kremer
PDF Acrobatics Without a Net
khk@khk.net
http://www.khkonsulting.com
Is Adobe Acrobat installed on the system? Your code will not work with Adobe Reader.
Sorry....I meant to say Adobe Acrobat 9.
And 'Yes' this code works in 9 but not in 10.
And you have Adobe Acrobat X ?
Yes, Adobe Acrobat X Standard it what comes up under the Windows XP Start menu.
Check whether you maybe also have some copy of Adobe Reader installed, could be confusing things.
Reader and Acrobat can peacefully coexist on the same system. I can even
have Reader and Acrobat run at the same time, and the VBA code still
"knows" what application to talk to. So that's very likely not the problem
either. What can cause problems is to have multiple versions of Acrobat
installed on the same system.
Karl Heinz Kremer
khk@khk.net
On Tue, Jan 29, 2013 at 11:49 AM, Test Screen Name <forums_noreply@adobe.com
Adobe Acrobat Acrobat X and Adobe Acrobat Distiller X are the only Adobe apps currently installed.
On PCs with Adobe Acrobat 9 and Distiller 9 installed I am not having any problems. Only with the PCs that have 10 installed.
Ok, that changes things Have you tried a new project? Do you run into
the same error when you start a new MS Word VBA project from scratch? What
you are doing is pretty basic, and it should definitely work. Because you
get past the first line that uses the OLE API, I assume that you have a
valid reference to Acrobat.tlb. From that point on, things should just
work.
I just pasted your code into a button handler of a new word document, and
the line you are having a problem with does not cause any problems. I run
into problems further down, when the code tries to use
So, whatever your problem is is not with Acrobat X, there must be something
wrong with your code project.
As I said, I would start to debug this with a brand new project and see if
you run into the same problem, if not, then see if you can copy and paste
code from the corrupt project to the new project. You will either end up
with a working project, or you will see what other parts are necessary to
make the code fail.
Karl Heinz Kremer
khk@khk.net
OK. So I did as you suggested.
On the PC with Adobe Acrobat X Standard I created a brand new Word document and built all my code/forms up from scratch. But unfortunately, I am running into the same issue. A "Type Mismatch" error at the same line of code.
As you mentioned, the line above compiles fine, but the next one crashes. Perhaps a bad Acrobat.tlb file??
I'm running out of ideas.
What if you start with a really simple VBA example? Take a look at this:
Private Sub CommandButton1_Click()
Dim AcroApp As Acrobat.CAcroApp
Dim theDocument As Acrobat.CAcroPDDoc
Dim bm As Acrobat.AcroPDBookmark
Dim thePath As String
thePath = "c:\temp\test.pdf"
Set AcroApp = CreateObject("AcroExch.App")
Set theDocument = CreateObject("AcroExch.PDDoc")
theDocument.Open (thePath)
MsgBox "Number of pages: " & theDocument.GetNumPages
theDocument.Close
AcroApp.Exit
Set AcroApp = Nothing
Set theDocument = Nothing
Set bm = Nothing
MsgBox "Done"
End Sub
If this still does not work, I would reinstall Acrobat to make sure that
the TLB is not corrupt.
Karl Heinz Kremer
khk@khk.net
Hi Karl,
Thanks for the code, but still no luck. Same error as before, at the same line: Set theDocument = CreateObject("AcroExch.PDDoc")
Perhaps my best option now is to get Adobe re-installed. Strange that the AcroExch.App doesn't cause a problem though.
Ran across this looking for something else.
Did you ever find an answer? If not, I may have a suggestion, odd as it may seem.
I am doing virtually the same thing on a system running Acrobat X Pro. One difference in your code and mine is that I do not explicitly type (if that's the right way to say it) my application variable as you do in the line "Dim acrobatApp As Acrobat.acroApp", nor do I use a related "set" statement for that particular variable. Apart from that, the rest of my code almost mirrors the flow of yours.
I realize not defining one's variables is not a best practice when writing code, but I also know my code works like a charm in this state. And I'm not even sure I did that on purpose as it was some time ago that I put it together, thanks to Karl's Ramblings on the subject. Go Karl!
Might be worth a try to comment out those two lines and see if your errors clear up. Finding out "why" will be interesting, but getting your code to work first will be even more interesting.
Just thought I'd put it out there.
Thanks.
Basically after I downgraded to v9 everything worked again, so I haven't really looked into much after that.
I had the same error (429 ActiveX component can't create object) at the same line when trying to create the same object using 10 but not in 9. I then sat down at a computer with Adobe Pro Extended and the code works just fine.
I am having the same problem with Windows 10, VBA for Excel and Adobe InDesign CS6 and Illustrator CS6 Type library. Same errors Type mismatch trying to instantiate the application. and then errors setting the document as a child of the app. I lost a $4000 job because of this.
You need Adobe Acrobat to combine PDF files.
