1. Re: 2:39 or 1:85 aspect ratio
JSS1138 Jan 30, 2013 9:11 AM (in response to lisaellensegal)Create a normal sequence that matches your footage. Then use a Crop preset to letterbox.
2. Re: 2:39 or 1:85 aspect ratio
lisaellensegal Jan 30, 2013 9:59 AM (in response to JSS1138)I am sorry. I read your post, I imported your presets (thanks) and I see that you are adding the appropriate crop effect. How do you export without black bars? Would you then set the correct frame height and width, then crop top and bottom at the source window?
If so, how do I calculate the correct number of pixels to crop and the correct pixel height and width? Would you just drag the crop marks to match the video?
3. Re: 2:39 or 1:85 aspect ratio
JSS1138 Jan 30, 2013 10:24 AM (in response to lisaellensegal)How do you export without black bars?
Are you sure you want to? This will be for computer or web playback only?
If so, use the Crop feature in the Export Settings dialog, top of the Source tab. Than adjust the export resolution appropriately.
4. Re: 2:39 or 1:85 aspect ratio
lisaellensegal Jan 30, 2013 11:16 AM (in response to JSS1138)Yes, to be clear, this question pertains to web/computer playback ONLY. Thanks for your help and your pre-sets.
Lisa
