Locked
"Error occurred while packaging the application... Can't load library" in Flash Builder 4.7 (iOS)
Feb 01, 2013 Feb 01, 2013
Been struggling to resolve this error since yesterday in Flash Builder 4.7 packaging an app for iOS.
Error occurred while packaging the application:
Exception in thread "Main Thread" java.lang.UnsatisfiedLinkError: Can't load library: C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\eclipse\plugins\com.adobe.flash.compiler_4.7.0.349722\AIRSDK\lib\aot\lib\llvm.dll
          at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1706)
          at java.lang.Runtime.load0(Runtime.java:770)
          at java.lang.System.load(System.java:1004)
          at adobe.abc.LLVMEmitter.loadJNI(LLVMEmitter.java:587)
          at adobe.abc.LLVMEmitter.<clinit>(LLVMEmitter.java:597)
          at com.adobe.air.ipa.AOTCompiler.generateExtensionsGlue(AOTCompiler.java:419)
          at com.adobe.air.ipa.AOTCompiler.generateMachineBinaries(AOTCompiler.java:1790)
          at com.adobe.air.ipa.IPAOutputStream.createIosBinary(IPAOutputStream.java:378)
          at com.adobe.air.ipa.IPAOutputStream.finalizeSig(IPAOutputStream.java:762)
          at com.adobe.air.ApplicationPackager.createPackage(ApplicationPackager.java:91)
          at com.adobe.air.ipa.IPAPackager.createPackage(IPAPackager.java:246)
          at com.adobe.air.ADT.parseArgsAndGo(ADT.java:571)
          at com.adobe.air.ADT.run(ADT.java:419)
          at com.adobe.air.ADT.main(ADT.java:470)
915
Community Beginner , Feb 01, 2013 Feb 01, 2013
Update:
My previous proposed solution (of installing the 64-bit JRE) resulted in a different problem. After multiple attempts and restarts I was unable to work in the Flash Builder IDE as it became unresponsive on load. Each time I had to use Task Manager to close the application.
Apparent Solution:
Close all applications running in Windows
Uninstall all versions of JRE (Java Runtime Environment)
Uninstall Flash Builder 4.7
Reinstall Flash Builder 4.7
In my case this seemed to be caused by a 32-bit installation of JRE (Java Runtime Environment) I had installed for an unrelated application. With JRE installed it's possible that Flash Builder was attempting but unable to use the 32-bit dlls?
Apparent Solution:
I installed the 64-bit version of JRE alongside it which appears to have resolved the problem.
Update:
Apparent Solution:
