I am trying to embed a you tube into a PPT for school. It requires the use of shockwave flash object. I have the most current shockwave and it wont work. Are the two separate? Where do I get shockwave flash object?
You should try to find a forum for PPT and post your inquiry there, or just search Google using terms like "PowerPoint Flash video tutorial".
Shockwave Flash Object is Flash Player; get it from http://get.adobe.com/flashplayer/otherversions/
If you are on Windows you may need to install both ActiveX and plugin versions (as I do not know which version PP uses).
[topic moved to Flash Player forum]
