8 Replies Latest reply: May 22, 2014 8:02 AM by Willam van Weelden RSS
    ehlpdhtm.js script error - Object doesn't support property or method 'Activate'
    JaredHess Community Member
      RH 9.0.2.271
      Windows 7 64-bit
      This "Object doesn't support property or method 'Activate' ehlpdhtm.js error all of a sudden started popping up when I view any of the chms I build from my file system.
      I initially through it was a 64-bit problem because if I view the chm from my file system I get the script error. But if I copy it to a 32-bit PC or run it from within RH (after it's compiled for example) or a 32-bit version of our software, it runs fine. (However, one of my co-workers tried it on her 64-bit machine and didn't receive any error.) In any case, it seems to be happening on my machine only.
      Anyway, it's not on every topic, but on every one that calls the ehlpdhtm.js script with this line of code, it appears to be happening:
      <script src="ehlpdhtm.js" type="text/javascript" language="JavaScript1.2"></script>
      I don't think hhactivex.dll plays with this js at all, but just in case, I unregistred and re-registered that dll to no effect. I also tried explicitly adding in ehlpdhtm.js as a baggage file. Again, to no effect.
      What could have changed on my system to make this start happening? And any ideas on how to fix it?
