Hi, I have a problem when I play videos in premiere is where most looks, but also happens to me in vlc, quicktime, youtube. It too fast, If you stop the video disappear.
i7 3930K
GTX 670 2GB, whit last drivers
Videos:
Canon 60d
1080p
h.264
Premiere Pro CS6
Which one?
It is not a PR problem, it is something else when it also happens with VLC, QuiRcktime and YouTube.
Gigabyte GTX 670 2GB OC
Drivers: 310.90
I'm back to compare VLC, youtube, quicktime and PP.
In PP you can see all the time, nonstop.
In VLC, youtube, QT maybe 3-4 times.
My Dell U2713H displays is, dual DVI.
I solved teh issue, i had AERO off. I turned on and everything works fine. Thanks
how do you turn AERO on?
THanks! actually, this doesn't help my situation with the horizontal lines. Changing the field options does; however once I render the sequence it reverts back to horizontal lines. Do you know how to permanently fix?
I have never seen this issue on either of my systems, so I'm not aware of any fix.
Drop the card in the 60D and hook it up onto a TV.
See if you see the same issue.
If so: its in the source.
Happends in all app, but in PP happends more, more lines than VLC. I'm going to try.
