27 Replies Latest reply on Feb 14, 2013 5:55 AM by Stan Jones
    Encore CS5.1 Motion Jitter when rendering
    DMEDIUS
      Hi guys
      Im Having problem when exporting on CS5.1 some places in the movie specially PAN & TILT shots are Jittering not clear
      Im working on Final Cut Pro on Full HD movie im exporting the movie from Final cut as it is  and transcoding with Encore. Im exporting Blu-ray
      I know that any file i import to Encore it will render again. so im doing that but when i watch the Blu-ray im not liking the quality
      anyone can help me please ??
      Thank you in Advance
        • 1. Re: Encore CS5.1 Motion Jitter when rendering
          DMEDIUS Level 1
          Looks like it will be harder than i thought.
          ok guys can anyone tell me how i make bluray when i finalize my movie with Final Cut Pro ??
          • 2. Re: Encore CS5.1 Motion Jitter when rendering
            Jeff Bellune Level 6
            We need some more info.
            Is your MOV file from FinalCut a progressive segmented file?  If it is, then Encore may be interpreting it incorrectly.
            Try this.  Export a short bit (that contains motion/panning/tilting) from FinalCut using the same settings you have been.  Open the Adobe Media Encoder and add the short file to the queue twice.  For the first instance, transcode it to H.264 or MPEG2 Blu-ray, making sure that the AME interprets it as progressive.  For the second instance, transcode it to the same format as the first one, but this time set the AME to interpret it as interlaced.
            Import both transcoded clips into a new En project, add them to timelines, and burn a test disc.  Use a BD-RE so you don't make a coaster.  Play the disc back in a hardware Blu-ray player hooked up to a TV.  Is there any difference in the clips?  Do either of them jitter?
            Jeff
            • 3. Re: Encore CS5.1 Motion Jitter when rendering
              DMEDIUS Level 1
              Thank you Jeff for you answer
              Movie is Filmed 1920x1080i and im exporting Apple Losseless 422
              I Heard about this Adobe Media Encoder ... they told me that it takes too much time, well my movie is about 4 Hours do you still recomand AME, and after AME Encore wont transcode them again ?
              by the way i made 5 minutes test from my movie by importing the file to After Effects and export it from the with the same settings as original and the problem is fixed maybe not 100% but 95% for sure
              what do you think about that ?
              1 more question this AME i have to download it from somehere or it comes with Adobe Package ?
              Thank you Jeff one more time
              • 4. Re: Encore CS5.1 Motion Jitter when rendering
                Did you do any of things I suggested?
                The AME is part of the Adobe package.
                Please read the article at the link below and let us know if your source footage is possibly PsF (progressive segmented):
                Things You Must Know About PsF (Progressive Segmented Frame) Recording. Bening PsF vs Malignant PsF | Pro Digital Group -- Professional Video Production Services
                Jeff
                • 5. Re: Encore CS5.1 Motion Jitter when rendering
                  Daguerre_Niepse
                  I have some similarities with the problem of DMEDIUS. I make a DVD once a year for the graduates of my school. I never had a problem. But this year the video are jittering when put on DVDs. If il look at them on my PC they are fine. I even put one on youtube as a test and it's fine. But when the movies are in Encore, they are jittering. Not all, but most of them.
                  I looked in forums and some people talked about Adobe media encoder, so i put them all in it "normalized" their format but with the same result.
                  The common point of the movies that are jittering is that they are powerpoints transformed to movies with Moyea PPT to video software. I used it for years with no problem. As previously stated they are fine when i look at them using Media player for example. But in Encore they always jitter even when i use the command to previsualize the movie (dunno the good word my software is in french.) as well when put on DVD.
                  Help would be greatly appreciated.
                  Thank you
                  • 6. Re: Encore CS5.1 Motion Jitter when rendering
                    DMEDIUS Level 1
                    Jeff
                    As i said my Footage is not Progressive and still didnt try with AME i will let u know what happenes with me
                    thank you
                    • 7. Re: Encore CS5.1 Motion Jitter when rendering
                      I want to make sure it didn't get altered during the export from Final Cut.  Please download MediaInfo and load your movie into it.  Post a screen shot of the video information using the tree view of MediaInfo.
                      Here's a link:
                      MediaInfo
                      Jeff
                      • 8. Re: Encore CS5.1 Motion Jitter when rendering
                        Are you transforming them as interlaced or progressive?  Does Moyea treat the PPT files as progressive on import?
                        Jeff
                        • 9. Re: Encore CS5.1 Motion Jitter when rendering
                          Daguerre_Niepse Level 1
                          I don't know about the type of information your asking me. As previously stated i use Encore once a year only. Do you have a link or a reference that i could use to identify the type of movie i have? BTW i changed them in Adobe media encoder. I thought that it would correct the problem but it did not.
                          Thank you for your answer!
                          • 10. Re: Encore CS5.1 Motion Jitter when rendering
                            Check all of your preferences and export settings in the Moyea software.  You should also download MediaInfo (link in post #7 above) and check the files from Moyea using that.
                            I suspect that you have an issue with field order.
                            Reference:
                            Interlaced video - Wikipedia, the free encyclopedia
                            Jeff
                            • 11. Re: Encore CS5.1 Motion Jitter when rendering
                              OK, here is the setting from moyea
                              MP4 file
                              VIDEO SETTINGS:
                              XVID
                              1280X720
                              16:9
                              Quality: medium
                              SOUND SETTINGS:
                              AAC
                              quality: medium
                              débit bianire (Dunno the word in english): 12800
                              taux d'échantillonage: 44100
                              stereo
                              When i change them with adobe media encoder, mediainfo tells me this:
                              All the film are:
                              F4V file
                              format: MPEG-4
                              Video codecs: AVC
                              Audio codec: AAC LC
                              Does this information help you in finding the probable cause?
                              • 12. Re: Encore CS5.1 Motion Jitter when rendering
                                Changing them with Adobe Media Encoder using those settings is causing more problems and is confusing the issue.  Don't do that.
                                Part of the problem is that Moyea is outputting HD (High Definition) files, and DVD requires SD (Standard Definition) files.  So Encore has to scale down the video, which can cause problems if it's not done carefully.  Better to export out of Moyea at DVD frame size: 720x576 for PAL.  Try exporting a very short clip from Moyea as a test, and add that to an Encore timeline.  Burn the Encore project to rewritable disc so you don't waste any blank media.
                                Jeff
                                • 13. Re: Encore CS5.1 Motion Jitter when rendering
                                  Hi Jeff,
                                  Sorry for the delay,
                                  I did as you asked, made a test with 720X576. Full of hope, i looked at it and it was all fine but when i put it in encore... still jittering.  So the format is OK (720X576) but still it's causing me trouble.
                                  About the PAL, i looked in the Moyea software and in the help files but i did not see anything about PAL or NTSC. Here in canada, we use NTSC. maybe the answer is here? have another idea?
                                  nice day
                                  • 14. Re: Encore CS5.1 Motion Jitter when rendering
                                    Sorry.  I didn't know you were in Canada.  I figured you were in France.
                                    For NTSC try 720x480, just to be sure.  But based on your 720x576 results, I don't think it will change anything.  However, there is one possible issue that it might fix so it may be worth your time to do a short test.
                                    I think this may be an issue with interlacing -- wrong field order or interlaced when it should be progressive (or vice-versa).  Do you use Premiere Pro to edit the video?  You may needhttp://www.videolan.org/index.html to sort out the interlacing there if it really is the issue.
                                    Jeff
                                    • 15. Re: Encore CS5.1 Motion Jitter when rendering
                                      DMEDIUS Level 1
                                      Hi Jeff
                                      sorry for the late answer.
                                      This is Media Info Results
                                      General
                                      Complete name : /Volumes/VIDEO/Lynn Decor.mov
                                      Format : MPEG-4
                                      Format profile : QuickTime
                                      Codec ID : qt
                                      File size : 2.00 GiB
                                      Duration : 2mn 21s
                                      Overall bit rate mode : Variable
                                      Overall bit rate : 122 Mbps
                                      Encoded date : UTC 2013-01-31 14:18:23
                                      Tagged date : UTC 2013-01-31 14:22:03
                                      Writing library : Apple QuickTime
                                      ©TSC : 25
                                      ©TSZ : 1
                                      Video
                                      Format : ProRes
                                      Format version : Version 0
                                      Codec ID : apcn
                                      Duration : 2mn 21s
                                      Bit rate mode : Variable
                                      Bit rate : 120 Mbps
                                      Width : 1 888 pixels
                                      Original width : 1 920 pixels
                                      Height : 1 062 pixels
                                      Original height : 1 080 pixels
                                      Display aspect ratio : 16:9
                                      Frame rate mode : Constant
                                      Frame rate : 25.000 fps
                                      Color space : YUV
                                      Chroma subsampling : 4:2:2
                                      Scan type : Interlaced
                                      Scan order : Top Field First
                                      Bits/(Pixel*Frame) : 2.401
                                      Stream size : 1.98 GiB (99%)
                                      Language : English
                                      Tagged date : UTC 2013-01-31 14:20:29
                                      Color primaries : BT.709
                                      Transfer characteristics : BT.709
                                      Matrix coefficients : BT.709
                                      Audio
                                      Format : PCM
                                      Format settings, Endianness : Little
                                      Format settings, Sign : Signed
                                      Codec ID : sowt
                                      Duration : 2mn 21s
                                      Bit rate mode : Constant
                                      Bit rate : 1 536 Kbps
                                      Channel(s) : 2 channels
                                      Channel positions : Front: L R
                                      Sampling rate : 48.0 KHz
                                      Bit depth : 16 bits
                                      Stream size : 25.9 MiB (1%)
                                      Language : English
                                      Menu
                                      Duration : 2mn 21s
                                      Language : English
                                      Encoded date : UTC 2013-01-31 14:20:29
                                      • 16. Re: Encore CS5.1 Motion Jitter when rendering
                                        Two things caught my eye.
                                        1. The video is interlaced, upper field first.  Verify that En is using upper field first when it encodes the video.  If it's not, then you need to create a transcoding preset that uses upper field first and use that to encode the MOV file.
                                        2. The Frame Size parameters versus the Original Frame Size parameters seems odd.  But I don't work with ProRes or FCP so maybe this is to be expected?  Anyway, if there really is some scaling going on when you transcode with En (or the AME, or Pr), then you will need to have Maximum Render Quality checked in the preset or export settings in order to avoid softening of the image.  This is especially true for interlaced footage.
                                        Jeff
                                        • 17. Re: Encore CS5.1 Motion Jitter when rendering
                                          Hi Jeff,
                                          You are right, even with 720X480 i have the same results. The software does not give me any settings regarding using NTFS or PAL tough. I looked everywhere i did not found it. I contacted the company but they are in vacation till february 16 .
                                          I will check about the interlacing. I'm learning pretty much about videos with this problem. Cool!
                                          • 18. Re: Encore CS5.1 Motion Jitter when rendering
                                            BTW i use Premiere por CS5. Can i use it to help me about the interlacing issue?
                                            • 19. Re: Encore CS5.1 Motion Jitter when rendering
                                              You should download MediaInfo as well.  Use it to examine the 720x480 file from Moyea and post a screenshot of the results (be sure to use the tree view of MediaInfo).
                                              If it is an interlacing issue, you can fix that in Pr by setting the timeline and the export to match the source footage.
                                              Jeff
                                              • 20. Re: Encore CS5.1 Motion Jitter when rendering
                                                Hi Jeff,
                                                As asked from you. With this software i can see it's NTFS.
                                                General
                                                Complete name                            : C:\Users\gigueref\Desktop\Copie de Halloween.mp4
                                                Format                                   : MPEG-4
                                                Format profile                           : Base Media
                                                Codec ID                                 : isom
                                                File size                                : 9.28 MiB
                                                Duration                                 : 1mn 23s
                                                Overall bit rate                         : 927 Kbps
                                                Writing application                      : Lavf52.104.0
                                                Video
                                                Format                                   : MPEG-4 Visual
                                                Format profile                           : Simple@L3
                                                Format settings, BVOP                    : No
                                                Format settings, QPel                    : No
                                                Format settings, GMC                     : No warppoints
                                                Format settings, Matrix                  : Default (H.263)
                                                Codec ID                                 : 20
                                                Duration                                 : 1mn 23s
                                                Bit rate                                 : 794 Kbps
                                                Width                                    : 720 pixels
                                                Height                                   : 480 pixels
                                                Display aspect ratio                     : 3:2
                                                Standard                                 : NTSC
                                                Color space                              : YUV
                                                Chroma subsampling                       : 4:2:0
                                                Bit depth                                : 8 bits
                                                Scan type                                : Progressive
                                                Compression mode                         : Lossy
                                                Bits/(Pixel*Frame)                       : 0.092
                                                Stream size                              : 7.95 MiB (86%)
                                                Writing library                          : XviD 1.2.1 (UTC 2008-12-04)
                                                Audio
                                                Format                                   : AAC
                                                Format/Info                              : Advanced Audio Codec
                                                Format profile                           : LC
                                                Codec ID                                 : 40
                                                Duration                                 : 1mn 23s
                                                Bit rate                                 : 128 Kbps
                                                Sampling rate                            : 44.1 KHz
                                                Stream size                              : 1.28 MiB (14%)
                                                Do you sse anythning wrong in that file?
