I have a sidebar item on the front page of my website that pulls a "featured pic" out of my photo gallery and keeps it there for the day. While it's not really important when that day starts and ends (people are of course, in all different time zones), I'd like to have the pic up for 24-hrs-ish.
I started to write a complicated script to check the date and rotate the pic every day, but then I thought I might do it the "cheap" way, and just cache the query for 24 hrs. The problem is, if I leave the page and return, I get a completely different pic. I'm thinking that since my query is in the request scope, the caching is failing because CF sees the query name as being different.
Here's my code:
<cfquery name="FeaturedPic" datasource="#request.dsn#" cachedwithin="#createtimespan(0,24,0,0)#" maxrows="1">
SELECT photos.pic_id
, photos.pic_file
, albums.album_url
, albums.album_name
, parents.album_name AS parent
, parents.album_url AS parenturl
FROM photos
INNER JOIN albums
ON photos.pic_album = albums.album_id
LEFT JOIN albums AS parents
ON parents.album_id = albums.parent_album
ORDER BY rand()
</cfquery>
Is my hypothesis about my caching correct, or is there something else I'm missing?
The code you posted shows the query to be in the variables scope, not the request scope. Turn on de-bugging to see if you are running a cached copy or not.
I can't change any settings (shared hosting), but I can do it locally tonight on my home machine. I'll see if I can reproduce the problem locally too. Thanks!
Alright, here's what I get from the debugging output (locally):
FeaturedPic (Datasource=cw_data, Time=0ms, Records=1, Cached Query) in /var/www/includes/cydebar.cfm @ 18:25:17.017
So it looks like it is indeed cached. And if I close out of my browser, wait ten minutes, then open that same page back up, I get the same pic (expected). However, on my shared host, if I close out of my browser, wait ten minutes (or so) then open the page back up, different pic. Hmmmm...
Caching is done at the server level. Only so much RAM is allocated to the cache and if it gets full, the next entry kicks out the oldest one, or something like that. This might be what is happening to you.
Ah, I hadn't even considered that. With a shared host, it's entirely possible.
I'll just live with it the way it is. My primary goal is not to have the featured pic change with each page load, and it accomplishes that fine.
Thanks for the input!
