I generated my Help project without errors. However, I am not able to scroll in IE to view the entire topic. Can you tell me how I change my settings to be able to view /scroll to see the entire topic in the IE browser. I am using Windows 7, 32 bit OS. Thank you.
Nicole
what was your help output? WebHelp, AIRHelp, HTML5 help, etc.?
Also can you explain what you mean by "unable to scroll"? Is there no scroll bar? Does it display correctly in other browsers?
The scroll bar was not visible. I am only using IE since that is what our customer uses. Thank you.
Nicole
If you are outputting to HTML5 why are your clients using IE? Surely they should be expected to run the output on a mobile device of the same type as you have setup in your screen profiles and layouts?
My output was HTML5. Thank you.
I noticed that too when I was playing around - the desktop default settings didn't scroll, but I didn't notice which browser was doing what
This is a bug in the Desktop HTML5 layout. See the last post in this thread for a solution: http://forums.adobe.com/message/4654937
Greet,
Willam
Thanks Willam for that - I hadn't started worrying about it because I have no need to use it yet.
Note to original poster - if you had picked the HTML5 forum in the first place, you too would have seen this bug/fix </grin
