1. Re: No more exporting clips from Source Monitor in Premiere CS6?
Ann Bens Feb 7, 2013 7:46 AM (in response to soom1976)I cannot remember exporting clips that way ever being possible.
Anyway in CS6 you can select a clip or clips, hit / (forward slash) followed by ctrl+M (Export Media).
2. Re: No more exporting clips from Source Monitor in Premiere CS6?
JSS1138 Feb 7, 2013 9:00 AM (in response to soom1976)CS6 works just like CS4 did on this one.
3. Re: No more exporting clips from Source Monitor in Premiere CS6?
Ann Bens Feb 7, 2013 9:46 AM (in response to JSS1138)Never knew that, indeed it does work in CS6.
Probably never had the need to export like that.
The / will take clips with in and outpoints.
4. Re: No more exporting clips from Source Monitor in Premiere CS6?
Thanks Ann, that speeds things up a bit, but I still need to select "Sequence In/Out" from the Source drop-down menu every time in the export window.
5. Re: No more exporting clips from Source Monitor in Premiere CS6?
Not in my case (I'm on Mac, maybe in Windows it's different?): in CS4 I double-click a clip in a timeline, it opens in the source monitor, and I click Export. I immediately get only this specific cut selected as a work area without any need to mark in/out, or to define work area. In CS6 just doesn't happen... Can you confirm that CS6 also does it and can you tell me your configuration and version?
6. Re: No more exporting clips from Source Monitor in Premiere CS6?
JSS1138 Feb 7, 2013 12:27 PM (in response to soom1976)I still need to select "Sequence In/Out" from the Source drop-down menu every time in the export window.
That actually doesn't work when you initiate export from the Source Monitor. Bug of some sort. If you want only part of a clip, you need to initiate it from the sequence and select Sequence In/Out in the Export Settings.
