Aligning text & graphics
Participant ,
Jul 17, 2008 Jul 17, 2008
I have text, often with a graphic, often in a table (imported from Word document) that either does not appear positioned correctly or is numbered wrong or both.
When I remove the numbering (from the toolbar), the text repositions into the left margin and I lose the formatting. Clicking TAB does not work. Changing the text to Normal does not work.
BTW, most of the text is InlineNormal types. Even changing it to Normal or removing the tag in the code does not seem to allow proper numbering. The numbering does not show in the Design view. Preview shows the sentence numbered, but it is the wrong numbering. I seem to remember that all text in Word documents should be Body, not Normal, before importing the document.
334
Advisor ,
Best practice for lists in RH:
1. Assign Normal to all list elements.
2. Select all list elements.
3. Click the Create a Numbered List button in the RH toolbar.
4. If you have any elements that should not be numbered, go into TrueCode and remove the LI tag from the element; also, remove the ending OL tag before that element and the new OL tag after that element.
If you need to come back and make significant changes to this list at a later date, it's probably simpler to undo the entire list, add/change/remove appropriate elements, and start over at Step 1.
Good luck,
Leon
Participant ,
Warning: style (p.InlineNormal24) is not defined and will be mapped to 'Normal'.
thanks for reply, will try next
Participant ,
True Code? You the HTML view or something else to edit out LI and OL tags?
RoboHelp Documentation
Download Adobe RoboHelp
