5 Replies Latest reply: Feb 16, 2013 1:16 AM by -hans- RSS
    Help change script from Alpha Channel to Photoshop path
    erblo007 Community Member
      Hello, I've put together this script that will set the clipping path of a selection to Alpha Channel, convert path to frame, and delete the contents.
      for (i=0; i<app.selection.length; i++)
      try {
      app.selection[i].images[0].clippingPath.clippingType = ClippingPathType.ALPHA_CHANNEL;
      } catch (e)
      // not interested if there is none
      try {
      mySel = app.selection[i]
      mySel.graphics[0].clippingPath.convertToFrame();
      mySel.graphics[0].remove();
      } catch (e)
      I need to change this to use the Photoshop Path method instead, with a Path Name of "Path 1", but I'm not sure how to do that, can anyone help?
      Also, is there a way to specify the clipping path options, specifically "include inside edges" and tolerance/threshold values through script?
      Thank you!
        • 1. Re: Help change script from Alpha Channel to Photoshop path
          -hans- Community Member
          it should be simply:
          aImageReference.clippingPath.appliedPathName = 'Path 1';
          "include inside edges" and tolerance/threshold values -> Valid only when clipping type is alpha channel or detect edges.
          • 2. Re: Help change script from Alpha Channel to Photoshop path
            Thanks for your reply. So I would replace 'ALPHA_CHANNEL' with 'PHOTOSHOP_PATH'. This line of code you sent, where does this fit into my code listed above?
            Also, I need to work with both Alpha and PS Paths, so I do need to include inside edges. How can I add that?
            • 3. Re: Help change script from Alpha Channel to Photoshop path
              it's not quite clear what your workflow should look like.
              So here are just the two examples of how to handle a Photoshoppath (currently on) and alphachannel (currently off).
              Assume a image selected:
              var currSel = app.selection[0];
              (currSel instanceof Image) ? processPath(currSel) : alert('Selection is not a picture.');
              //(currSel instanceof Image) ? processAlpha(currSel) : alert('Selection is not a picture.');
              //Process a photoshoppath
              function processPath(aImageRef)
                  pathNames = aImageRef.clippingPath.photoshopPathNames;
                  pl = pathNames.length;
                  while(pl--)
                    if  (pathNames[pl] == 'Path 1')
                        aImageRef.clippingPath.appliedPathName = 'Path 1';
                        alert('Applied Photoshoppath Path 1');
                        exit();
                  //process a alphachannel
                  function processAlpha(aImageRef)
                  //there may be zero to ++ alphachannels, just choosed the first here
              var alphaChannelName =  aImageRef.clippingPath.alphaChannelPathNames[0];
              (alphaChannelName != undefined) ? setAlphaChannel(aImageRef, alphaChannelName) : alert('No Alphachannel avaiable.'); exit();
                  //apply settings for alphaChannel
                  function setAlphaChannel(aImageRef, alphaChannelName)
                     with (aImageRef.clippingPath)
              appliedPathName = alphaChannelName;
              includeInsideEdges = true;
              threshold     = 30; //number (range: 0 - 255)
              tolerance    = 3 ; //number (range: 0 - 10)
              restrictToFrame = true;
              invertPath = false;
              insetFrame = '5 pt';
              alert('Applied Alphachannel: ' + alphaChannelName);
              exit();
              Happy scripting
              Hans-Gerd Claßen
              • 4. Re: Help change script from Alpha Channel to Photoshop path
                Thank you for the help, I tried using this script and I got the message 'selection is not a picture'.
                I made a sample layout of what I'm trying to do. I need to be able to select both pictures at the same time, run the script and get the result shown below.
                https://www.dropbox.com/s/u3oxbqcpfnkp0n3/sample.indd
                The script I posted at the top does everything I need, except it does not include the inside edges.
                • 5. Re: Help change script from Alpha Channel to Photoshop path
                  my example code expects a image to be selected ... not a graphic frame.
                  If you spend a bit of your time inspecting it, you'll see that you've got everything to solve your issue either using alpha channel or photoshop path.
                  Give it a try!
                  P.S. One tipp: Guess you can forget about the alphachannel as the images have got a photoshop path, which is more accurate -> results would be better.
