After having made several attempts to migrate from a ColdFusion 8 Standard server to a ColdFusion 10 Standard server, it feels like I am "almost" there. I'm using the 64 bit installer from Adobe's website.
I'm using a Windows Server 2008 (64 bit) server with IIS 7.5.
The installation itself goes smooth and the services start and are running. But at the end of the installation it says "ColdFusion Installed, but with errors" and it generates a log file.
The log file reads:
Migration Error: : Check that "C:\ColdFusion8" is a valid directory and is an installation of either ColdFusion MX 6 or ColdFusionMX 7
and further down says:
Status: WARNING
Additional Notes: WARNING - Could not migrate settings from previous version of ColdFusion
Custom Action:
com.macromedia.ia.action.MigrateColdFusionAction
Status: ERROR
Additional Notes: ERROR - class com.macromedia.ia.action.MigrateColdFusionAction NonfatalInstallException null
The applicationHost.config file has new XML referencing the ColdFusion 10 directory, but IIS is still using ColdFusion 8. I'm also going to guess that the settings in the CF Administrator have not been migrated based on the message in the log above.
Can you check if your IIS was configured with ColdFusion 8 in 32-bit or 64-bit?
I had the same issue you need to remove the handlers for coldfusion 8 from IIS from the ISAPI handlers.
but the issue I have now it coldfuison 10 is stuck on the import of the setting from coldfusion 8
anyone with any suggestion will be helpfull also is appache required for coldfusion 10 to run if I am using IIS
Thank you
Did you remove the ColdFusion 8 connector, before you install ColdFusion 10?
You can use either IIS or Apache as per your requirement.
Thank you
I did rename the connectors for the coldfusion 8 added a -old at the end of them so I can rool back to 8 in case of an issue and that worked for me.
but the migration from coldfusion 8 to coldfusion 10 did not work for me and was stuck on the migration page (restarted coldfusion when you try to login to the admin you get redirected to the waiting page for the migration waited almost 30 min )
so I removed Coldfusion10
and reinstalled it this time I had to skip the migration and just moved the neo-datasource.xml file from the c:/coldfusion8/lib folder to c:/coldfusion10/cfusion/lib
I had to update the passwords for th s db users as for the scheduled task I only had 2 and redid them manualy
