Like Colum, welcome to the Forums!
(The following assumes the WebHelp Pro scenario you outlined)
>>>1. How do I set the window to have the right
frame display initially, without the left index frame? I want to
leave the index frame so that the user can access it if neccesary.
1. Make sure WebHelp Pro is your primary layout.
2. Create a new Window, call it OnePane and select the
tickbox in Window properties for One Pane and click OK. (This means
the Navigation pane (Contents, Index, Search, etc.) are hidden when
first launched.
3. Bring up the WebHelp Pro single source layout wizard.
4. Tick the box: Show navigation pane link in topics (this is
what allows the user to opt to see the Index and navigation pane if
they want.
5. Be sure to select "OnePane" as your default window you
just created and complete the wizard to publish.
6. Caveat: There is a shortcoming when you view locally from
the authoring machine. You will not be able to see the effects of
your changes. These can only viewed in a web browser pointed to
your actual WebHelp Pro site.
7. Publish to the RoboEngine server to view all the changes
you made and notice the "Show" link that allows the user to reveal
the navigation pane.
>>>2. Our Help System is in HTML, but I am thinking
of using WebHelp Pro (from a dedicated server). When I View Primary
Layout, the index frame and button at the top of the form do not
display. I get the yellow box located just below the Internet
Explorer toolbar saying 'To help protect your security, Internet
Explorer has resticted this file from showing active content that
could access your computer. Click here to for options....'. That
could be a real pain for 1200 users. Is there a way to if off for
RoboHelp WebHelp Pro?
I believe you may be encountering something that is only seen
by you because you're viewing it locally. When published, the user
would not see this. To remove this annoying message, go to Internet
Options > Advanced > scroll down to Security and tick the box
"Allow active content to run on My Computer." (Also, for more info,
do a search in the forums for "Mark of the Web")
>>>3. Can I create my own skin?
Sure. Use the WebHelp skin editor as you normally would. Give
the skin a name and use it when you publish.
Hope this helps.
John
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Newport, Oregon
