6 Replies Latest reply on Feb 13, 2013 9:34 AM by Flex harUI
    URLVariables send parameter as array
    flashharry! Level 1
      I need to send an array of data with URLVariables so that when its received by the php script it see them as an array.
      var SEARCHFIELD:Array = new Array();
      SEARCHFIELD.push([{PATHTYPE:1,PATHTYPELOGIC:0}]);
      var params:URLVariables = new URLVariables();
      var search_volume:Array = new Array();
      search_volume.push('/Volumes/Customers/Stock_Pictures');
      search_volume.push('/Volumes/Customers/mercedes');
      params.search_volume = search_volume;
      params.SEARCHFIELD = SEARCHFIELD;
      searchData.data = params;
      Gives me this in php
      Array
          [search_volume] => /Volumes/Customers/Stock_Pictures,/Volumes/Customers/mercedes
          [SEARCHFIELD] => [object Object]
      What I want is this in php.
      Array
          [search_volume] => Array
                  [0] => /Volumes/Customers/mercedes
                  [1] => /Volumes/Customers/Stock_Pictures
          [SEARCHFIELD] => Array
                  [0] => Array
                          [PATHTYPE] => 1
                          [PATHTYPELOGIC] => 0
      Thanks in advance
      Flash
        • 1. Re: URLVariables send parameter as array
          Madhav Subedi
          if possible, use AMFPHP; it will make your job quite easier.
          • 2. Re: URLVariables send parameter as array
            flashharry! Level 1
            Normally I use JASON and http service, the issue with this is that I do not have any access to the PHP source code. The php code is not mine and is encoded. I know what I need to send to the php script, API if you will. I don't need to even process the results, need to post the data then let the PHP take over.
            I need to do a lot of user data gathering and business logic, then post this data and show the results via the PHP. I just need to be able to pass an array of data to the php script.
            in javascript you would just use literals examplename[0].name = xx, I want to do the same with URLVariables....
            TIA
            flash
            • 3. Re: URLVariables send parameter as array
              flashharry! Level 1
              ok I figured out first part and got a array to go across
              //this is the bit that works as an array using [] in the quoted name
              params["search_volume[]"] = search_volume;
              this gives me......
                          [0] => /Volumes/Customers/Stock_Pictures
                          [1] => /Volumes/Customers/mercedes
              in the php post data
              I now need to figure out nested (multidimensional) arrays
              any ideas?
              flash
              • 4. Re: URLVariables send parameter as array
                flashharry! Level 1
                ok figured it out
                params["SEARCHFIELD[0][PATHTYPELOGIC]"] = "0"
                params["SEARCHFIELD[0][PATHTYPE]"] ="1";
                            [0] => Array
                                    [PATHTYPE] => 1
                Phew the answer was simple, why did it take so long
                • 5. Re: URLVariables send parameter as array
                  jayarjo
                  For me it sends comma-separated list instead of array.
                              [0] => /Volumes/Customers/Stock_Pictures, /Volumes/Customers/mercedes
                  rather than:
                  • 6. Re: URLVariables send parameter as array
                    Flex harUI Adobe Employee
                    What does your code look like?  I think you have to assign each element.
