Hi All,
I have a FM 10 book of nearly 200 pages and 7 chapters. It has a nice index (index of markers).
Today, I found out that the index is not getting updated when I am updating the book. The new entries are not coming.
The option "Generate Table of contents, Lists and Indexes" is selected while updating. And it was working fine previously, this problem much came in recently. I noticed it today.
When I try to generate a new index, the generated file comes blank. Though the index entries in the book are all right, FM is not detecting them.
I will very much appreciate some quick help in this matter.
Com
> I imported these (all formats including masterpages and ref pages)
> from the old index file and now it is looking all the same.
That's Plan B, and is a more reliable route, but is more work than Plan A.
> ... I am not being able to ressuract the old index as you stated ...
What happened?
How about a couple of screenshots; the reference page and book with index setup would be pretty useful.
Don't shout at me, but you haven't got the files set to Exclude for any reason, have you?
Also check the icons in the book menu. Generated files get a different icon. If Frame thinks the file is no longer generated, it won't have that unique icon.
If that's happened, it can be easy to fix. Report back for the steps.
Hi Error,
I had the same problem in the past. The index of one of my books were no longer reccognized as a generated file by FM and it was not updating. The icon also changed to be the same as the other book files.
Can you please give me the steps to re-recognize the file in FM?
> ... steps to re-recognize the file in FM?
Assuming your book is MyTome.book and the IX file is MyTomeIX.fm
This works on alternate Wednesdays and in FM releases that are prime numbers.
I do not have 2 IOMs defined in the Reference page.
After some R&D, I am being able to add a new index in the following way:
1. Click/Select the book file.
2. Click Add > Standard index.
But the new index file do not seem to use our master page. But I imported these (all formats including masterpages and ref pages) from the old index file and now it is looking all the same.
My question is: This will be pretty much identical to the old index, right? I just want to make sure I am not spoiling up. Everything looks the same though. Do I need to change a few settings somewhere?
Error, I am not being able to ressuract the old index as you stated, need to go with the new one.
Perhaps I misunderstood your initial post...
If you are creating a standard index (with a suffix of IX), you likely have 2 IX definitions in your reference pages. When you import the ref pages back into your new doc, you reintroduce the problem.
Either reformat your new index, or avoid importing your reference pages from the bad IX into the new and you should be fine.
What happened?
Hi Error,
What happened?
It fails at last. After deleting the the newly created index, I (re-)renamed the old index to replace, but again it failed to update, remains innert.
Do you have 2 IOM defined within the reference pages of your first chapter?
