11 Replies Latest reply: Aug 13, 2014 2:36 PM by thewinelake42 RSS
    Problem installing CF10 on Ubuntu 12.04
    alexlake Community Member
      Just been trying to install CF10 with Apache2 and it was all looking reasonably good, but when I try to use the CFIDE adminstrator, I get a Tomcat error:
      HTTP Status 500 -
      type Exception report
      message
      description The server encountered an internal error () that prevented it from fulfilling this request.
      exception
      javax.servlet.ServletException: java.lang.NullPointerException coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:129) coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59) org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414) org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:203) org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539) org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298) java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) java.lang.Thread.run(Thread.java:662)
      root cause
      java.lang.NullPointerException coldfusion.CfmServlet.init(CfmServlet.java:82) coldfusion.bootstrap.ClassloaderHelper.initServletClass(ClassloaderHelper.java:121) coldfusion.bootstrap.BootstrapServlet.init(BootstrapServlet.java:59) org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472) org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98) org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:928) org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:414) org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:203) org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:539) org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:298) java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) java.lang.Thread.run(Thread.java:662)
      note The full stack trace of the root cause is available in the Apache Tomcat/7.0.23 logs.
      The coldfusion-error.log seems pretty harmless:
      Feb 14, 2013 1:06:16 PM org.apache.catalina.core.AprLifecycleListener init
      INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: /opt/coldfusion10/jre/lib/amd64/server:/opt/coldfusion10/jre/lib/amd64:/opt/coldfusion10/ jre/../lib/amd64:/opt/coldfusion10/cfusion/lib:/opt/coldfusion10/cfusion/lib/_ilnx21/bin:/ opt/coldfusion10/cfusion/lib/international::/usr/java/packages/lib/amd64:/usr/lib64:/lib64 :/lib:/usr/lib
      Feb 14, 2013 1:06:16 PM org.apache.coyote.AbstractProtocol init
      INFO: Initializing ProtocolHandler ["ajp-bio-8012"]
      Feb 14, 2013 1:06:16 PM org.apache.catalina.core.StandardService startInternal
      INFO: Starting service Catalina
      Feb 14, 2013 1:06:16 PM org.apache.catalina.core.StandardEngine startInternal
      INFO: Starting Servlet Engine: Apache Tomcat/7.0.23
      Feb 14, 2013 1:06:21 PM org.apache.catalina.util.SessionIdGenerator createSecureRandom
      INFO: Creation of SecureRandom instance for session ID generation using [SHA1PRNG] took [5,003] milliseconds.
      Feb 14, 2013 1:06:24 PM org.apache.catalina.core.ApplicationContext log
      INFO: ColdFusionStartUpServlet: ColdFusion: Starting application services
      INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 20.4-b02
      Could not determine local hostname.
      Any other diagnostics I should include?
