Locked
How can I install FMS on Ubuntu 12.04 LTS Server 64bit ??
Guest
Jan 20, 2013 Jan 20, 2013
How can I install FMS on   Ubuntu 12.04 LTS Server 64bit ?? I follow the install guide, but it dont work.I get this error
"A reqzured package, libcap, was not found on your linux_86_64 Debian." But Licap is alread installed..please help
13.1K
Guest
The latest libcap libraries on Ubuntu 12.04 cause problems with fmsedge process and fmsedge process crashes. For installing Flash Media Server on ubuntu 12.04, install the libcap2-2.17  from http://archive.ubuntu.com/ubuntu/pool/main/libc/libcap2/libcap2_2.17-2ubuntu1.1_amd64.deb
Download the file using wget and install the deb using sudo dpkg –i libcap2_2.17-2ubuntu1.1_amd64.deb
Then install FMS.
Guest
Jan 21, 2013 Jan 21, 2013
Hi, I try it, but i get this error:
my serverinfo:
Prozessor: Intel Sandy Bridge G530
CPU-Leistung: 2 x 2,4 GHz
Arbeitsspeicher: 4 GB
Guest
Sorry, that was for AMD processor. Try installing libcap from http://archive.ubuntu.com/ubuntu/pool/main/libc/libcap2/libcap2_2.17-2ubuntu1_i386.deb which is for Intel processors.
Download the file using wget and install the deb using sudo dpkg –i libcap2_2.17-2ubuntu1_i386.deb
Guest
Jan 22, 2013 Jan 22, 2013
i just installed a fresh ubuntu.. i get this error.. i try to install libcap2_2.17-2ubuntu1_i386.deb
but i get an other error this one
Guest
Jan 23, 2013 Jan 23, 2013
I tried installing AMS on fresh installation of Ubuntu 12.04. For AMS to install and work on ubuntu, I had to do following things:
Then try installing AMS. It should work fine.
Guest
I cant remove it, because ntp is using libcap.. and now?
Guest
Stop ntp using command sudo /etc/init.d/ntp stop and then try above steps.
Guest
Jan 24, 2013 Jan 24, 2013
@ Chandan_Abhishek
thx u for your help;)
i try it, but i get still the error..
Jul 23, 2014 Jul 23, 2014
Chandan_Abhishekis correct. Only thing the wrong libnspr link. here is the correct link. http://security.ubuntu.com/ubuntu/pool/main/n/nspr/libnspr4_4.8.9-1ubuntu2_amd64.deb
Mine is working now
Guest
Feb 16, 2013 Feb 16, 2013
I went into terminal . went to the installAMS maybe installFMS for you and I edited in NANO and look for the line " exit_no_libcap(){  "   I changed it to " exit_no_libcap-dev (){" and I did the same thing to the "exit_wrong_libcap " I only added  "-dev" to both sections. Install started right up
