I created a web service using VB.net that is used to access a
handful of .dbf files. The VB.net code works, the files are read
and data is returned. I want to be able to access the web service
using CF so I can manipulate the data and move it to SQL Server to
be accessed via a web application. However, when I try to access
the web service I get the following:
Cannot perform web service invocation GetData.
The fault returned when invoking the web service operation
is:
AxisFault
faultCode: {
http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: org.xml.sax.SAXException: Deserializing
parameter 'GetDataResult': could not find deserializer for type {
http://www.w3.org/2001/XMLSchema}anyType
faultActor:
faultNode:
faultDetail:
http://xml.apache.org/axis/}stackTrace:org.xml.sax.SAXException:
Deserializing parameter 'GetDataResult': could not find
at
org.apache.axis.message.RPCHandler.onStartChild(RPCHandler.java:277)
at
org.apache.axis.encoding.DeserializationContext.startElement(DeserializationContext.java:1035)
at
org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRecorder.java:165)
at
org.apache.axis.message.MessageElement.publishToHandler(MessageElement.java:1141)
at
org.apache.axis.message.RPCElement.deserialize(RPCElement.java:236)
at
org.apache.axis.message.RPCElement.getParams(RPCElement.java:384)
at org.apache.axis.client.Call.invo... ''
The data is being returned from the web service as xml. The
web service converts the DataSet to xml and then returns it to the
calling cfc.
I have racked my mind and scoured the internet looking for
information. Any help is greatly appreciated.
Thanks.
