Flash Builder 4.7
The following line in the -app.xml file generates an invalid namespace error although AIRSDK 3.6 appearsas installed in the prefs dialog.
application
xmlns=http://ns.adobe.com/air/application/3.6Thnks in advnce for the help.
I'm seeing the same thing.
I think one of the descriptor XMLs is out of date.
Not sure which but, for example, the 3.6 archive only has up to 3.5 in airsdk.xml:
<versionMap>
<descriptorNamespace>http://ns.adobe.com/air/application/3.5</descriptorNamespace>
<swfVersion>18</swfVersion>
</versionMap>
It is probably just a case of duplicating that with 3.6 but I don't know the swfVersion
Ah... Scrub that, I've just done a fresh download and restart from the beginning. Now the airsdk.html appears correct.
Third time lucky...
Thks a lot for passing us the info.
We appreciate you doing this, since we face the same error "Could not resolve <s:ViewNavigatorApplication> to a component implementation."
Will try and hope it will work here as fine as for you.
Best regards
Bruno
Envoyé : jeudi 7 mars 2013 16:25
À : info@informatique-education.fr
Re: Invalid namespace
created by Gaius Coffey<http://forums.adobe.com/people/Gaius+Coffey> in Using Flash Builder - View the full discussion<http://forums.adobe.com/message/5129293#5129293
Still not working…
Rid of the previous error but now obtain the following :
Processus terminé de manière inattendue.
invalid application descriptor: Unknown namespace: http://ns.adobe.com/air/application/3.6
In the prefs window, AIRSDK 3.6 appears as installed, but in the –app.xml file only “xmlns=http://ns.adobe.com/air/application/3.6” is accepted.
I’ve tried both methods to install the zip file : 1 - Merge and 2 - delete previous content before unzipping.
Any ideas ?
Thks in advance for help.
Bruno
Thanks a lot It seems very interesting we Will try it tomorrow.
Envoyé de mon iPhone
Le 7 mars 2013 à 16:25, "Gaius Coffey" <forums_noreply@adobe.com<mailto:forums_noreply@adobe.com>> a écrit :
I'm not sure whether or not it has had any effect whatsoever, but (now you have the correct SDK) I know that I replaced the compiler as per http://helpx.adobe.com/flash-builder/kb/overlay-air-sdk-flash-builder.html [Hint: By "Optional" for backup, they mean "Compulsory unless you want to cry in anguish". ]
It could be that there is a mismatch there that might have caused your "Processus terminé de manière inattendue." error.
G
