1. Re: "Black" clip on import
Jim_Simon Feb 19, 2013 9:11 AM (in response to fetusticianpj)For oddball videos, I use the following to convert. (Grab the latest version 5, not 6.)
2. Re: "Black" clip on import
John T Smith Feb 19, 2013 9:21 AM (in response to fetusticianpj)What is inside the file?
Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
http://forums.adobe.com/thread/592070?tstart=30
For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
3. Re: "Black" clip on import
fetusticianpj Feb 19, 2013 9:40 AM (in response to John T Smith)Thanks Jim and John !
OK XviD4PSP open and has the following error message: CONVERT: Connot convert if width isn't Mod2!
and Media info reports the following:
General
Complete name : C:\Users\pjeanty.INNERVISION\Documents\Cases\Cardiac\Anatomy\Video-clips\lvot.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 154 MiB
Duration : 9s 810ms
Overall bit rate : 132 Mbps
Video
Format : JPEG
Codec ID : MJPG
Duration : 9s 810ms
Bit rate : 132 Mbps
Width : 975 pixels
Height : 735 pixels
Original height : 736 pixels
Display aspect ratio : 4:3
Frame rate : 55.556 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 3.310
Stream size : 154 MiB (100%)
4. Re: "Black" clip on import
Jim_Simon Feb 19, 2013 9:45 AM (in response to fetusticianpj)Try a different output format. MP4 seems to work pretty well. There's even a lossless option under Video Encoding if you want it.
5. Re: "Black" clip on import
fetusticianpj Feb 19, 2013 9:54 AM (in response to Jim_Simon)The GE equipment has only two option, uncompressed and Cinepack. the clip i use are "uncompressed"
I can play them in http://mpc-hc.org/ and capture with Camtasia, but this is a little clumsy ...
6. Re: "Black" clip on import
Ann Bens Feb 19, 2013 9:56 AM (in response to Jim_Simon)You do not need to convert mjpeg.
Just install the demo.
http://www.mainconcept.com/products/apps-plug-ins/codecs-conversion/motion-jpeg.html
7. Re: "Black" clip on import
fetusticianpj Feb 19, 2013 10:25 AM (in response to Ann Bens)Thanks Ann,
MJPEGCodec_RETAIL_v3.2.4 did not install properly,and the email to MainConcept bounced back on Gmail. I tried to download several time to make sure this was not a corrupted download. No change.I tried to run in Win compatibility mode, same problem (error 1628: Failed to complete installation, OK)
I use a Dell Optiplex 9010 Intel Core i7-3770 cpu at 3.40 GHz, 8 GB ram and 64 bit OS (Win 7 pro, SP1.
9. Re: "Black" clip on import
fetusticianpj Feb 19, 2013 10:56 AM (in response to Ann Bens)You mean you want to peak at the clip and suggest I transfer it ?
10. Re: "Black" clip on import
fetusticianpj Feb 19, 2013 11:02 AM (in response to fetusticianpj)I can't really transfer the file for HIPPA reasons, I would have to get a release from the patient, a complicated issue.
11. Re: "Black" clip on import
Ann Bens Feb 19, 2013 12:57 PM (in response to fetusticianpj)No its a download for the codec.
12. Re: "Black" clip on import
Jim_Simon Feb 19, 2013 1:46 PM (in response to fetusticianpj)The GE equipment has only two option
I mean try a different output format from Xvid4PSP.
13. Re: "Black" clip on import
fetusticianpj Feb 19, 2013 1:49 PM (in response to Jim_Simon)I found an OK work-around. Using FreeMake (http://www.freemake.com/) and selectign XVID, I got a format that Premiere can read, from that I can now convert to B&W, crop, export to Sorensen and then compress to SWF... Pfeww .. Thanks everyone for helping !
