I keep on getting the following error message when I try to update Adobe Extension Manager 6.0.5 . I don't know why this is happening. Can anyone help me?
Extension Manager 6.0.5 Update
Installation failed. Error Code: U44M1P7
@John
I tried this but with no success: just got a slightly different error message U44M2P7. Dowloaded 6.04, installed and then tried to update through Adobe Application Manager. No good. Then tried updating as you suggested, but same story.
What error messages did you uncover in the installation logs for the updates Kxlivo34?
Hi Jeff
The error message was U44M2P7.
However I think I may have solved the problem, at least for the time being. First I deleted the entire Adobe Extension Manager folder in Applications. Then I downloaded 6.0.4 again and installed it, without using Application Manager. Then I downloaded the patch for 6.0.5 and installed that, again without Application Manager; EM was indicated in Info as 6.0.5. Seems therefore to be OK, but have not tried to use Application Manager or open Extension Manager since, as I do not need to currently.
Thanks for the help on this.
Kxlivo34
Ok the U44M2P7 error only means the installation failed. The actual error message is in the installation log. This information is referenced in the document offered in message #1. You can find also find details on how to review the install log at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
Thanks. Will review.
I give up. Things are getting too technical for me. Thanks for trying to help.
Bigbandss@aol.com you are welcome to work directly with our support team for guided assistance. You can reach our chat support at http://adobe.ly/yxj0t6.
