1. Re: Sizing tab panels
Vinayak_Gupta Feb 17, 2013 7:50 PM (in response to kenackr)This is most likely happening due to the much larger sized slide show in the center tab that is causing the jump in order to maintain the size of the slide show container and hence leading to consistency in the height of each of the tabbed panels.
If this is the case, you would need to resize the Hero image of the slide show accordingly and move the caption and count closer to the image that would reduce the overall size of the slide show container. You should then be able to resize the tabbed panel.
Vinayak
2. Re: Sizing tab panels
kenackr Feb 18, 2013 10:05 AM (in response to Vinayak_Gupta)Vinayak,
Thank you for the response.
I eliminated the the caption, count, and previous & next previously. The only thing left is the picture frame itself.
I will test your suggestion by removing the slide show to see what happens to the tab boundry.
Will advise when completed with test.
Ken
3. Re: Sizing tab panels
kenackr Feb 19, 2013 12:38 PM (in response to Vinayak_Gupta)Vinayak,
It turns out that I had dragged the envelope boundary from the Tab line itself to near the bottom of the original frame size when constructing the original slide show and that was what caused the over size page display. I have now fixed it.
Thanks for your help!
Ken
