I've inserted one flash into Presenter 7 (I use office2010).
After published, flash always stop in the first frame.
And I try to remove the action script in the first frame (stop();) and publish it again, now flash can work but another problem caused.
The slide inserted flash can not replay from the first frame if I move to other slide and go back to this one, it will go on playing from what I played last time.
Does anyone know how to fix this problem?
thank you so much!!!
What version of Presenter 7 are you using? What Action Script language was used to create your flash object, AS2 or AS3?
Hi Jorma,
I use Presenter 7.07 and AS2.
I've found a solution yesterday.
After changing Presenter publish setting, it can correctly work now.
thank you for your reply.
So you know, Presenter 7.0.7 is an AS3 application. So you will probably either need to revert back to 7.0.6 or change your SWFs to AS3 for them to work properly. The playback issues with the different versions of AS may not always come up, but at some point it will.
