4
illustrator opens PDF with corrupted characters
Feb 22, 2013 Feb 22, 2013
When i open a PDF in Illustrator the characters become corrupted. It looks like "#D)9! etc.
Apples preview and Acrobat shows the text right. But when opened in illustrator everything is wrong. The font I use is plain Arial.
Viktor
Import and export
129.7K
correct answers 2 Correct answers
Community Beginner , May 07, 2014 May 07, 2014
I experience the same issue. My workaround is to open the pdf in Acrobat and save it as eps. Illustrator (CS6 in my case) will open the eps file and the text will display correctly.
My experience is consistent with Larry Schneider's answer in that my problem documents all come from MS Office using Calibri(Theme Body).
I routinely use Illustrator to tidy up plots of scientific data which I originally create by printing and saving to pdf in other apps (mainly Kaleidagraph and Omnigraffle) and I have
Community Beginner , Mar 23, 2018 Mar 23, 2018
Thanks hunterk53973462, I had the same issues "KRVA" described with a graph that was exported to pdf. I usually open in Illustrator to manipulate it. Sometimes the text turns into unreadable characters. Opened the PDF in Adobe Acrobat Pro, under Menu > Save As Other > Archivable PDF/A. Opened it with Illustrator retained readable text. I noticed one outlined line of text and another line of text was individually broken up into individual characters but the rest of the text was intact. Yeah!
Adobe
Guide ,
Illustrator is not a universal PDF editor. You can usually open a PDF that was created in Illustrator (with Illustrator editing capabilities) but a PDF created from any other program is a risky. What is it you are trying to do?
I did a presentation of a website in Illustrator with several art boards (pages) and saved as PDF.
Unfortunately I opened and saved it in Acrobat because I needed to change the default view size to 100% 72 dpi.
Now when I have to go back and open the PDF in Illustrator to make changes the characters in my PDF have become totally corrupted.
Also Illustrator dont get the artboard/multiple pages concept. It only want to open one page.
Guess the best solution is to stay away from PDF in the future and use Powerpoint or Keynote instead.
Did you save the PDF with Illustrator compatibility?
You should, if you want to have the ability to edit the PDF later.
I don't get your point about opening single pages of a multiple page PDF in Illustrator. You might want to explain what exactly you did.
First i did a PDF with multiple pages (artboards) in Illustrator and saved as PDF.
Then I opened it in Acrobat and changed the view option for the PDF (to 72 DPI / 100%). Then save in Acrobat.
Then I needed to edit it again in Illustrator.
But when I open the PDF in illustrator (that have been saved in Acrobat) all text is corrupted. But it looks fine in Apple preview and Acrobat.
My problem is that the text looks like !#9D"% when opened in illustrator (but Acrobat renders it fine).
(Guess the artboard functionality got lost when I saved in Acrobat.)
Guide ,
I just tried this in Illustrator 6 and Acrobat 10 and it worked fine. I suspect you used an earlier version of Acrobat that did not support multiple artboards? If you used the Illustrator default to save your PDF, the fonts should have been embedded and should not have changed after saving in Acrobat. You can check for embedded fonts in Acrobat (File> Properties> fonts). Did your file originate in Illustrator? PDFs from Powerpoint, and Publisher can be problematic, because of un-embedded fonts, even when placed in Illustrator.
Feb 23, 2013 Feb 23, 2013
Hi Luke,
I use Illutsrator CS6 and Acrobat 10.1.1. And I have checked that box on your screenshot.
But you solved one thing. The type that is messed up comes from a flowchart that was created in Powerpoint. I used Illustrator to clean it up and changed the fonts to Arial. The textblocks that was originally created in Powerpoint is the ones that are messed up.
This is how it went:
1. Flow chart created in Powerpoint and exported as PDF.
2. PDF is opened in Illustrator - everything looks nice.
3. I change some view settings in Acrobat and save.
4. Open the file again in Illustrator and it looks like ****.
Anyway, I have recreated the artwork.
But it's still a mystery for me why Acrobat and preview show it fine and Illustrator don't.
The problem comes from the Calibri font used in MS Office. It's the same with Excel when copy/pasting a chart from Excel to AI if the Calibri(Theme Body) font was used. You must make the change in PP before moving the file to AI.
I routinely use Illustrator to tidy up plots of scientific data which I originally create by printing and saving to pdf in other apps (mainly Kaleidagraph and Omnigraffle) and I have never had an issue with any of these files.
May 24, 2017 May 24, 2017
I typically just stalk these forums, but I signed in to say THANK YOU. Most excellent workaround.
Nov 11, 2021 Nov 11, 2021
Acrobat > eps > Illustrator fixed this for me. Saved me a ton of work. Thank you.
Sep 23, 2022 Sep 23, 2022
thanks LOADS for this workaround - you really have saved me!!!! Duncan, Spain
I should add that the text appears correctly but as compound paths, so this work around may not be that useful if you need to retain the text editability.
In order to outline a text you don't need this workaround. Instead place the file in Illustrator (don't embed) and then flatten transparency ("outline text" checked)
Thank you, Monika. Yours is a superior way to get the file opened in Illustrator in the same form as my workaround.
Do you know of a way to avoid the outline text? My preference is to have editable text, correctly displayed.
I'm not a very experienced user and am baffled by the apparent interaction of transparency and correct display of text. Can you recommend a reference document that explains what is happening?
As Larry already mentioned: avoid Calibri.
In other cases (nor relevant for Excel) ligatures force outlining of text, so they need to be avoided.
But sometimes even that won't help and you just have to live with it.
In  my case, my co-author has embedded Excel charts in Word and I don't have access to the original data or charts. The charts use Cambria as the font for labels. I've taken the Word file, selected all and changed the font to Times by applying a new style. I've also selected some chart labels and changed the font from Cambria to Times. All the text that was changed from Calibri or Cambria to Times correctly displays as editable text in Illustrator now. All the text that remained in Cambria is corrupted.
Thank you for your advice, Monika and Larry, and note that Cambria should join the list of fonts to avoid as well.
Wish I was clever enough to figure out how to select all text within the embedded charts and change them all to Times or Helvetica.
Guide ,
May 08, 2014 May 08, 2014
Not sure if this will work for you, but save the Word file as a PDF, Open it in Acrobat and go to Tools> Content> Edit object (this step varies, depending on which version of Acrobat you have). With luck you will be able to select just the chart. If you can, control-click it and choose edit object. Save it as a new file, edit it (change the font) and place it into your Illustrator file. You can choose which application with which to open the chart by going to Acrobat> Preferences> Touch up. If you have Pitstop, an Acrobat plug-in, you should be able to change the font right in Acrobat.
Oct 02, 2016 Oct 02, 2016
Please can someone answer this question?  The pdf should open in Illustrator without the text all being corrupted.
What is the solution to this?
Have you read the complete thread?
And expect text corruption when it wasn't made in Illustrator originally.
Nov 02, 2016 Nov 02, 2016
I had a similar problem:
I had a pdf report given to me by a coworker which they wanted to see mocked up in a different layout, when I opened the pdf in illustrator each character appeared as a box with an x in it.  The font used was Arial.  To fix this problem, I used the following steps:
1. Make sure the document is closed everywhere
2. Open the document in Acrobat Pro
3. Extract each page you need to edit as its own document (through the 'organize pages' feature in Acrobat)
4. Open each single page document in Acrobat
5. Select 'Edit Text and Images'
6. Select each text box individually and change the font to an adobe font.  I used 'Adobe Garamond Pro', I have only tested this with fonts which are named 'Adobe xxxx'.
7. Save and close each individual page in Acrobat
8. Open each individual page in Illustrator.  You should now have a more editable document.
Jan 06, 2017 Jan 06, 2017
the problem started when I changed from Excel 2011 to Excel for Mac version 15.
First Microsoft started to use Calibri font and with Excel 2011 I could change the sheet to Arial, save it as pdf.
I could open the pdf with Illustrator 6 or CC and it looked normal. I could change fonts and changed line, colors.
I use Illustrator to make look graphs nice for the financial publications I work on.
To avoid all the problems written above I would suggest go back to Excel 2011, click right on the picture and save as pdf.
It works good for me.
Dec 26, 2017 Dec 26, 2017
This may be an old question but many still encounter the problem of getting Microsoft table files (Word, Excel) into Illustrator.
Mine was to have a Table made in Word, styled (re-designed/re-done, if you will) in Illustrator—CS6 in my case—meaning, that I needed the table text data editable in Illustrator as well.
a. FIrst, I isolated the Word table and saved it as another file and saved as PDF; also printed as PDF.
b. Second, I copied the Word table and pasted it in Excel and saved it as and Excel file from which I saved and printed as PDF.
In both instances above—and like most of you— I've tried some solutions here, even checking for Calibri or any MS fonts that might have been used or carried over to avoid corrupting data entries like "#D)9!" in OP's post (luckily, Arial was used, so I didn't encounter that in this particular project). However, the Table data was converted into un-editable text outlines (you can edit its color or size). As mentoned, I needed the text to be editable as well.
So I've been trying out several workflow combinations offered here and elsewhere for 2 days until I realized this morning that I could:
  • Place the Excel file I created ("b," above), into InDesign (CS6) and;
  • Export it as PDF. (You have to have InDesign as in my case.)
Then,
  • I opened the InDesign-exported PDF in Illustrator and voila, the table formatting is untouched and the text characteristics are preserved.
From there, I did the table design in Illustrator as necessary.
I guess having a Microsoft product (Word, Excel) "intervene" in our thought or work process seem to complicate the process but going back to some basic Adobe workflows worked for me. I hope this helps.
MIght I add that the table file placed into Illustrator become grouped objects:
the strokes become individual lines, the text data, headers, column and row data, e.g.—while they remain editable as their original properties like font, size, style the same—also become individual lines of text that can be changed in Illustrator and so forth.
