Problem with returning query from Coldfusion Web Service
Guest
Jan 11, 2007 Jan 11, 2007
I have created a web service through Coldfusion. I am able to access all the functions except for those that have a returtype="query". I am invoking the web service from within a Coldfusion template. Supposedly there should be no issues in doing this. However I am receiving the following error message when I attempt to invoke the web service method that returns a query:
Could not perform web service invocation "getCreditCardList" because AxisFault faultCode: { http://schemas.xmlsoap.org/soap/envelope/}Server.generalException faultSubcode: faultString: [org.apache.axis.AxisFault : ; nested exception is: coldfusion.xml.rpc.CFCInvocationException: [coldfusion.runtime.NoOperScope$ScopeDisabledException : The requested scope application has not been enabled.][]; nested exception is: coldfusion.xml.rpc.CFCInvocationException: [org.apache.axis.AxisFault : ; nested exception is: coldfusion.xml.rpc.CFCInvocationException: [coldfusion.runtime.NoOperScope$ScopeDisabledException : The requested scope application has not been enabled.][] faultActor: faultNode: faultDetail: { http://xml.apache.org/axis/}stackTrace: AxisFault faultCode: { http://schemas.xmlsoap.org/soap/envelope/}Server.generalException faultSubcode: faultString: [org.apache.axis.AxisFault : ; nested exception is: coldfusion.xml.rpc.CFCInvocationException: [coldfusion.runtime.NoOperScope$ScopeDisabledException : The requested scope application has not been ena...
Any advice on what is causing this would be much appreciated. I am currently running CFMX 6.1
Thank you in advance for any help you may offer.
Advanced techniques
735
is your cfquery tag using an application variable? Maybe a dynamic
datasource name?
hth
Tim Carley
www.recfusion.com
info@NOSPAMINGrecfusion.com
Guest
You nailed it on the head. Thanks for the quick response.
Dec 01, 2014 Dec 01, 2014
Dear All Technology Expert's,
I have a query related to Coldfusion SOAP services, that is most commonly asked in all the forum's but NONE of them has got answer.
If there is NO solution so I think Adobe has to come up with some patches so developer can able to do some customization.
I like to share with you all, in all other language ( PHP, JAVA, .NET etc) this option is available and you can customize the error.
Ok let me again explain the very basic error:
SOAP Request:
<soapenv:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Header/>
   <soapenv:Body>
   </soapenv:Body>
</soapenv:Envelope>
SOAP Response:
  <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
   <soapenv:Body>
      <soapenv:Fault>
         <faultcode>soapenv:Server.userException</faultcode>
         <faultstring>java.lang.Exception: Body not found.</faultstring>
         <detail>
            <ns1:stackTrace xmlns:ns1="http://xml.apache.org/axis/">java.lang.Exception: Body not found.
  at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:121)...</ns1:stackTrace>
            <ns2:hostname xmlns:ns2="http://xml.apache.org/axis/">Coldfusion Error</ns2:hostname>
         </detail>
      </soapenv:Fault>
   </soapenv:Body>
</soapenv:Envelope>
HOW we can customize the error, in all other languages you can simple customize the error like
Other languages SOAP response:
   <soapenv:Body>
      <soapenv:Fault>
         <faultcode>BODY_NOT_FOUND</faultcode>
         <faultstring>Body is missing in your request</faultstring>
      </soapenv:Fault>
   </soapenv:Body>
</soapenv:Envelope>
But the same is NOT possible in Coldfusion, right?
AS you know it is vulnerability to display exception messages in the response.
We are developing this web service to access  from other language website (PHP, .NET).
We are also planning to upgrade server the Coldfusion 11, but do you think there is any solution with latest Coldfusion version.
Please response only if you know about these issue's or solution.
Niyaz
Documentation
