Can anyone suggest how to
- Eliminate the drop shadow that appears under and on the right side of the viewer?
- Instead, I want a thin line - or no line - all the around the viewer to outline the actual slide
- Or, ideally, how can I enlarge the viewer so it fills more of the background. In the example below, all the white space around the slide is actually "background"
Not sure how to eliminate the drop shadow around the bottom and right side of the presentation. I'd dig around in the XML of the published presentation and see if you can find something there.
as to the Presentation taking up more of the window, the shape of the presentation is based on the shape of the PPT slides. So a square presentation will always look like the image you have above. If you made the PPT deck rectangular, it may fill the screen better.
