Hi
I have a problem with formatting that is breaking inconsistently when I generate my project.
The formatting of my stylesheet:
An example of a section of content: "Planning and preparation"and "Training" = Heading 6. the rest of the bulleted text is a multi-level list style based on Normal
The HTML (I included a section of code above the problem section to show that it is not different):
The generated output:
I cannot see why the section below the <h6> Planning and preparation is in bold!! It is also not consistent. In another similar topic with the same layout, the text below the H6 is not bold.
Can anyone help?
What output are you generating to?
Also, can you post your complete html code for the topic and the css code for your style sheet? That might help determine if there's a rogue tag or something causing the bold. Also, is it only this topic that's having the issue?
This might help too: http://forums.adobe.com/message/3898855#3898855
(from an issue I had with WebHelp styles not showing up properly)
Hi Jared
I am generating WebHelp only. It isn't only this topic. It seems to only happen to Normal text after using Heading 6. But it doesn't happen everywhere where Normal text is followed by H6. I have various similar topics and it only happens to some of them.
HTML code:
<?xml version="1.0" encoding="utf-8" ?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta name="template" content="Pragma.htt" />
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="OriginalFile" content="6. Warehousing.docx" />
<meta name="generator" content="Adobe RoboHelp 10" />
<title>6.1.15 Train WHS resources</title>
<link rel="stylesheet" href="..\default.css" type="text/css" />
</head>
<body>
<h3>6.1.15 Train WHS resources</h3>
<h5>Purpose</h5>
<p>Ensure that the learners:</p>
<?rh-list_start class="Bullet_Multilevel" style="list-style: rh-list; list-style: rh-list;" ?><p
style="text-indent: -0.5cm; margin-left: 0.5cm;">understand and comply
with the principles of the WHS business process at the client before it
goes live</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">are fully compliant
with the client’s documented standards and procedures.</p><?rh-list_end ?>
<h5>Responsible role</h5>
<p>Project engineer</p>
<h5>Target audience</h5>
style="text-indent: -0.5cm; margin-left: 0.5cm;">Client resources
involved in the WHS process, eg data capturers, operators, artisans, technicians,
foremen and supervisors (who may be contractors).</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">Client’s warehouse
personnel staff</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">ACC staff for an
ACC@Client or a Service Support Centre</p><?rh-list_end ?>
<h5>Best practices</h5>
style="text-indent: -0.5cm; margin-left: 0.5cm;">Ensure that the training
is interactive and that learners are fairly assessed.</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">The learners must
be able to perform the tasks covered in the assessment.</p><?rh-list_end ?>
<h5>Inputs</h5>
style="text-indent: -0.5cm; margin-left: 0.5cm;">WHS training material</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">WHS training assessment</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">Guidelines for trainers</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">Training Attendance
Form (customised)</p><?rh-list_end ?>
<h5>Tasks</h5>
<h6>Planning and preparation</h6>
style="text-indent: -0.5cm; margin-left: 0.5cm;">Review the training
guidelines.</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">Print the customised
WHS training material as a handout for the learners.</p><?rh-list_end ?>
<h6>Training</h6>
style="text-indent: -0.5cm; margin-left: 0.5cm;">The learners complete
the Training Attendance Form.</p><?rh-list_end ?>
style="text-indent: -0.5cm; margin-left: 0.5cm;">Train the learners
in:</p><?rh-list_end ?>
<?rh-list_start class="Bullet_Multilevel" level="2" mc="1" ic="1" style="list-style: rh-list;
list-style: rh-list;" ?><p style="text-indent: -0.5cm;
margin-left: 1cm;">5S principles</p><?rh-list_end ?>
margin-left: 1cm;">warehouse
layout</p><?rh-list_end ?>
margin-left: 1cm;">coding
and binning of MRO items</p><?rh-list_end ?>
margin-left: 1cm;">stocktaking</p><?rh-list_end ?>
margin-left: 1cm;">On Key
functionality, if applicable</p><?rh-list_end ?>
margin-left: 1cm;">all WHS
procedures documented in the Standards Manual.</p><?rh-list_end ?>
<?rh-list_start class="Bullet_Multilevel" mc="1" ic="1" style="list-style: rh-list;
margin-left: 0.5cm;">Assess
the learners to ensure that they understand the WHS processes and are
competent in using the tools involved.</p><?rh-list_end ?>
margin-left: 0.5cm;">Present
a certificate to each learner who passed the assessment.</p><?rh-list_end ?>
<h5>Deliverables</h5>
and ACC resources are competent in the WHS standards and procedures.</p><?rh-list_end ?>
margin-left: 0.5cm;">Populated
margin-left: 0.5cm;">Results
from the learner assessment.</p><?rh-list_end ?>
</body>
</html>
Stylesheet:
/*Created with Adobe RoboHelp 10.*/
body {
font-family: Arial;
background-color: #ffffff;
font-size: 10.0pt;
margin-top: 0pt;
/* PHeading 1-4 */
h1 {
font-weight: bold;
color: #35365b;
margin-top: 22pt;
margin-bottom: 0pt;
page-break-after: avoid;
font-size: 18pt;
x-next-class: ;
x-next-type: p;
h2 {
font-weight: bold;
font-size: 14.0pt;
margin-top: 22pt;
margin-bottom: 0pt;
color: #35365b;
x-next-class: ;
x-next-type: p;
h3 {
font-weight: bold;
font-size: 12.0pt;
margin-top: 20pt;
margin-bottom: 0pt;
color: #35365b;
x-next-class: ;
x-next-type: p;
h4 {
font-weight: bold;
font-size: 11.0pt;
color: #35365b;
margin-top: 16pt;
margin-bottom: 0pt;
x-next-class: ;
x-next-type: p;
/* PLabel */
h5 {
margin-top: 14pt;
margin-left: 0cm;
font-weight: bold;
font-size: 11.0pt;
margin-top: 14pt;
margin-bottom: 0pt;
color: #a7a9ac;
x-next-class: ;
x-next-type: p;
/* PText Bold */
h6 {
font-size: 10pt;
margin-left: 0cm;
margin-top: 12pt;
margin-bottom: 0pt;
margin-right: 0cm;
font-weight: bold;
x-next-class: ;
x-next-type: p;
/* PText */
p {
font-size: 10pt;
margin-left: 0cm;
margin-top: 6pt;
margin-bottom: 0pt;
margin-right: 0cm;
p.TOC {
margin-top: 2pt;
margin-bottom: 2pt;
margin-left: 0cm;
p.Preamble {
font-size: 10pt;
margin-top: 6pt;
margin-bottom: 0pt;
margin-right: 0cm;
margin-left: 0cm;
color: #a7a9ac;
font-style: italic;
p.Image {
font-size: 10pt;
margin-top: 6pt;
margin-bottom: 0pt;
margin-right: 0cm;
margin-left: 1cm;
a {
display: inline "text-decoration:" underline;
a.popupspot {
color: #733f49;
A:link {
color: #733f49;
text-decoration: underline;
A:visited {
color: #733f49;
A:hover {
color: #733f49;
A:active {
color: #733f49;
a.expandspot {
color: #733f49;
cursor: hand;
font-style: italic;
text-decoration: none;
span.expandtext {
font-style: italic;
font-weight: normal;
color: #733f49;
a.dropspot {
cursor: hand;
color: #733f49;
font-style: italic;
a.glossterm {
color: #733f49;
cursor: hand;
font-style: italic;
span.glosstext {
font-style: italic;
color: #733f49;
/* List styles */
ol {
margin-left: 0.5cm;
margin-top: 0pt;
margin-bottom: 0px;
margin-right: 0cm;
ul {
margin-left: 0.5cm;
margin-top: 0pt;
margin-bottom: 0px;
margin-right: 0cm;
list-style: disc;
li {
margin-top: 6pt;
a.breadcrumbs {
color: #733f49;
display: inline;
font-size: 8pt;
rh-list.Heading_Numbered {
x-lvl-1-p-tag: h1;
x-lvl-1-format: "<x>.";
x-lvl-1-margin: 20px;
x-lvl-1-text-indent: -20px;
x-lvl-2-p-tag: h2;
x-lvl-2-format: "<1>.<x>";
x-lvl-2-type: decimal;
x-lvl-2-margin: 30px;
x-lvl-2-text-indent: -30px;
x-lvl-3-p-tag: h3;
x-lvl-3-format: "<1>.<2>.<x>";
x-lvl-3-type: decimal;
x-lvl-3-margin: 40px;
x-lvl-3-text-indent: -40px;
x-lvl-4-p-tag: h4;
x-lvl-4-format: "<1>.<2>.<3>.<x>";
x-lvl-4-type: decimal;
x-lvl-4-margin: 50px;
x-lvl-4-text-indent: -50px;
x-lvl-5-p-tag: h5;
x-lvl-5-format: "<1>.<2>.<3>.<4>.<x>";
x-lvl-5-type: decimal;
x-lvl-5-margin: 60px;
x-lvl-5-text-indent: -60px;
x-level-count: 5;
rh-list.Bullet_Multilevel {
x-lvl-1-type: disc;
x-lvl-1-format: "<x>";
x-lvl-1-margin: 0.5cm;
x-lvl-1-text-indent: -0.5cm;
x-lvl-1-p-tag: p;
x-lvl-2-type: disc;
x-lvl-2-format: "<x>";
x-lvl-2-margin: 1cm;
x-lvl-2-text-indent: -0.5cm;
x-lvl-2-p-tag: p;
x-lvl-3-type: disc;
x-lvl-3-format: "<x>";
x-lvl-3-margin: 1.5cm;
x-lvl-3-text-indent: -0.5cm;
x-lvl-3-p-tag: p;
x-lvl-4-type: disc;
x-lvl-4-format: "<x>";
x-lvl-4-margin: 2cm;
x-lvl-4-text-indent: -0.5cm;
x-lvl-4-p-tag: p;
x-level-count: 4;
table.Table_Normal {
padding: 0px;
x-border-spacing: 0px;
x-row-pat-1: 1;
x-row-pat-1-name: t1Row;
x-row-pat-count: 2;
x-row-pat-2: 1;
x-row-pat-2-name: t2Row;
x-1st-row: 1;
x-1st-row-name: t1st;
x-last-col: 1;
x-last-col-name: last;
border-left-style: Solid;
border-left-width: 1px;
border-left-color: #a7a9ac;
border-top-style: Solid;
border-top-width: 1px;
border-top-color: #a7a9ac;
font-size: 10pt;
vertical-align: top;
margin-top: 6pt;
margin-left: 1cm;
margin-right: 0cm;
margin-bottom: 12pt;
table.Table_Normal td {
padding-left: 10px;
padding-right: 10px;
padding-top: 0px;
padding-bottom: 4px;
p-class: p;
table.Table_Normal tr.t1st td {
font-weight: bold;
padding-top: 10px;
border-right-style: Solid;
border-right-width: 1px;
border-right-color: #a7a9ac;
border-bottom-style: Solid;
border-bottom-width: 1px;
border-bottom-color: #a7a9ac;
table.Table_Normal tr.t1Row td {
table.Table_Normal tr.t2Row td {
table.Table_Normal tr.t1st td.last {
table.Table_Normal tr.t1st td:last-child {
table.Table_Normal tr.t1Row td.last {
table.Table_Normal tr.t2Row td.last {
I've recreated your topic and css and everything appears just as it should in both IE8 and FF when run locally. Where is the help placed and what browsers are you using? Also is the same issue seen to other user's PCs?
Yes, same issue seen on other users' PCs. And the weird thing is, every time I generated different topics had bold sections.
But...I just managed to fix it: I added "font-weight: normal;" to the <p> style code in the .css.
So it now looks like this:
p {
font-size: 10pt;
margin-left: 0cm;
margin-top: 6pt;
margin-bottom: 0pt;
margin-right: 0cm;
And the problem is gone!
Thanks for your help.
