I have a client who needs to upload larger images or CAD designs. Is there any problem or limitation with allowing these uploads via BC ?
Also, the form's I've created for him are very complex.... user selected details like ring size, shank size, cut, etc. using mm and carats.
Jeff
- File size limits are 100mb per file.
- Not sure what you meaning in regards to forms you can make as you need to.
- You can create login securezones and pages with content such as forms if you need to
- To use the Database on another system with BC you will have to use API, or export it and import it into the BC site.
I mean if I have a form already constructed, there is no way to simply import it from an old site into BC, right? I'm thinking the database field names would not correspond to the BC database. I was just wondering if the field design could be used or if I have to start from scratch..
No, you need to rebuild the form in your BC site. You can keep the layout as long as you update the form action ID and any custom field ID's need to be updated to relate to their database equivelent.
