3 Replies Latest reply on Feb 28, 2013 12:59 PM by Tim Cunningham-ACP
    Secured file download in IE8
    ErieCFMaster
      Ok here's the problem I have some generated PDFs that contain sensitive information that can't live in the web root.
      I allow users to view them via a secured admin interface using the following code:
      <cfheader name="Content-Disposition" value="inline; filename=Export.pdf">
      <cfcontent type="application/pdf" file="#pdfFile#" />
      Works fine except when users are running IE8 on XP SP3, these users get a blank screen and nothing happens. Yes, they have acrobat, and so far it has failed on two versions 9 and 10.
      So I started to check for browsers and added the following if IE8:
      <cfheader name="Content-Disposition" value="attachment; filename=Export.pdf">
      <cfcontent type="application/octet-stream" file="#pdfFile#" />
      and again it works fine everywhere but IE8 on XP. So I tried mimicing a PHP script using the following:
      <cfsetting enablecfoutputonly="yes">
      <cffile action="READ" file="#pdfFile#" variable="FileData">
      <cfheader NAME="Expires" value="Thu, 19 Nov 1981 08:52:00 GMT">
      <cfheader NAME="Cache-Control" value="must-revalidate, post-check=0, pre-check=0">
      <cfheader NAME="Cache-Control" value="no-store, no-cache, must-revalidate">
      <cfheader NAME="Pragma" value="no-cache">
      <cfheader name="Content-Type" value="application/force-download">
      <cfheader name="Content-Type" value="application/octet-stream">
      <cfheader name="Content-Type" value="application/download">
      <cfheader name="Content-Transfer-Encoding" value="binary">
      <cfoutput>#FileData#</cfoutput>
      Still no go. Please if anyone has a solution to make this work in ColdFusion I would appreciate the help!!!
