1. Re: How Do I output Custom CRM Fields?
scottdouglas999 Sep 19, 2012 8:07 AM (in response to Liam Dilley)I'm trying to get this to work to no avail...
I have ceated an Extended CRM Field that has a series of check boxes. I inserted the "Edit Customer Details" form on a page. In the custome record I just want to display the selection of the field, not the entire list of checkboxes. I also wanted to use tis field (The selected checkbox) in the checkout form. Anyway the code looks like this:
<tr>
<td><label>Premium Seating Boxes</label><br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_0" value="PSB 1 - Regina Pats" />PSB 1 - Regina Pats<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_1" value="PSB 2 - CKCK TV" />PSB 2 - CKCK TV<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_2" value="PSB 3 - Molson Breweries" />PSB 3 - Molson Breweries<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_3" value="PSB 4 - Coca-Cola" />PSB 4 - Coca-Cola<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_4" value="PSB 5 - All-Rite Plumbing" />PSB 5 - All-Rite Plumbing<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_5" value="PSB 6 - Dilawri Group" />PSB 6 - Dilawri Group<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_6" value="PSB 7 - Yara-Sask Ferco" />PSB 7 - Yara-Sask Ferco<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_7" value="PSB 8 - Leipert Financial" />PSB 8 - Leipert Financial<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_8" value="PSB 9 - Evraz" />PSB 9 - Evraz<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_9" value="PSB 10 - SaskTel" />PSB 10 - SaskTel<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_10" value="PSB 11 - Evraz" />PSB 11 - Evraz<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_11" value="PSB 12 - Brandt Tractor LTD." />PSB 12 - Brandt Tractor LTD.<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_12" value="PSB 14 - Viterra" />PSB 14 - Viterra<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_13" value="PSB 15 - Leader Post" />PSB 15 - Leader Post<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_14" value="PSB 16 - The Co-Operators" />PSB 16 - The Co-Operators<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_15" value="PSB 17 - Mosaic" />PSB 17 - Mosaic<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_16" value="PSB 18 - Harvard Western Insurance" />PSB 18 - Harvard Western Insurance<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_17" value="PSB 19 - Regina Pats" />PSB 19 - Regina Pats<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_18" value="PSB 20 - Bayer Corp." />PSB 20 - Bayer Corp.<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_19" value="PSB 21 - Fries Tallman" />PSB 21 - Fries Tallman<br />
<input type="checkbox" name="CAT_Custom_434349_142115" id="CAT_Custom_434349_142115_20" value="PSB 22 - Sask Gaming" />PSB 22 - Sask Gaming
<script type="text/javascript">function setSelectedCheckbox(radioObj,options) {optionsToSelect = options.split(',');for(var i = 0; i < radioObj.length; i++) {radioObj[i].checked = false;if(optionsToSelect.indexOf( radioObj[i].value) != -1 ) {radioObj[i].checked = true;}}}; setSelectedCheckbox(document.getElementsByName('CAT_Custom_434349_142115'),'{module_custo merfield,142115,434349}');</script>
</td>
</tr>
So I grabbed the section {module_customerfield,142115,434349} and iserted it in the form but it doesn't display anything at all. Is this because it's checkboxes? Any help on this would be greatly appreciated.
2. Re: How Do I output Custom CRM Fields?
Matthew_Wooler Sep 25, 2012 5:25 PM (in response to Liam Dilley)This is great Liam, things have slightly changed in the system since you created this but it is actually quite straight forward once the custom field is setup correctly. I found after a while I had to attach the custom field to one of the 'entities' being Contacts, Companies, Cases, Opportunities, Orders.
If I created the field but not attach it then it would not show up when trying to extract the data form the 'Update User Details Form' from within the Secure Zone module.
Once I figured this out it was great because the system now shows you the module tag code when going to apply to page so you do not actually have to go hunt for it.
Pitty this data code is not just made avaialve to see in the CRM and save everyone hassel but this is better than nothing.
Good stuff.
3. Re: How Do I output Custom CRM Fields?
Liam Dilley Sep 25, 2012 6:31 PM (in response to Matthew_Wooler)Only as of Today Matthew with the toolbox, will update this later.
4. Re: How Do I output Custom CRM Fields?
Matthew_Wooler Oct 4, 2012 3:33 PM (in response to Matthew_Wooler)Actually as a slight updated I have since discovered the custom fields need to be attached to the Contacts entitie in order for it to show up in CMS to extract the module code. Attaching it to any other will not work.
5. Re: How Do I output Custom CRM Fields?
Liam Dilley Oct 4, 2012 3:57 PM (in response to Matthew_Wooler)That is not true Matthew, I am using it for something quite extensive other then that and just double checked and working great.
It depends on the context of use though, so if incorect will not work, this is true.
The key is that It has to be the right association in regards to the person logged in. -
6. Re: How Do I output Custom CRM Fields?
Matthew_Wooler Oct 4, 2012 4:09 PM (in response to Liam Dilley)Maybe I am applying it in the wrong way but I just built one this morning and went through the entire process again before responding to this. To extract the data from the 'Customer Update Details Form' for custom fields I can only see the extended CRM form if it attached to the 'Contact Entitie' first. It will not appear if attached to 'Companies, Cases, Opportunities, and or Orders'. I am sure there are other methods as well to grab the module code but this is the only way to have it appear using this specific process outlined.
7. Re: How Do I output Custom CRM Fields?
Todd H&M Mar 1, 2013 3:41 PM (in response to Liam Dilley)Liam,
Do you know if there is a way to output web form fields from a CRM case assigned to a specific user? I would like a user to login to a secure area and be able to see the content they have previously submitted via a web form.
So far I've sort of got it working but I'm only able to get some basic meta case info like the case date and number assigned to the user but not the actual unique form fields that were submitted.
I've got a page that references the 'customer cases layout (detailed list). That's allowing me to pull in the info I mention above but I've not been able to cobble together some sort of BC tag to pull in the actual details of the case.
Thanks, Todd
8. Re: How Do I output Custom CRM Fields?
Todd H&M Mar 1, 2013 3:52 PM (in response to Todd H&M)I think I've figured it out using {tag_subject} in the list view, now I'm exploring how to show the detailed view at the list level so the user doesn't need to go to another page to see the case details {tag_crmform}.
9. Re: How Do I output Custom CRM Fields?
Liam Dilley Mar 1, 2013 7:11 PM (in response to Todd H&M)You can ajax it in for example
10. Re: How Do I output Custom CRM Fields?
Marden-web-design Mar 3, 2013 6:38 AM (in response to Liam Dilley)This is just what i was looking for except i want to show all customers instead of the only the one who is logged in. I am creating a auction bid site and i want to be able to show all bids on the details page of the list view webapp and detail web app.
I extended crm field to customer data and made a field called Bid amount.
The problem is it only shows the one bid from the customer that is logged in thru secure zone. I want to show all bids from everyone. How can i do that?
If you say ajax can you give me an example of how to do that please.
Test page to show bid
http://makeoffer.mardenwebdesign.com/test
I want all bids to show here.
http://makeoffer.mardenwebdesign.com/make-offer - list view
http://makeoffer.mardenwebdesign.com/products/sealy-king-mattress - detail view
Dennis
11. Re: How Do I output Custom CRM Fields?
Marden-web-design Mar 3, 2013 7:06 AM (in response to Matthew_Wooler)It only works to the cases field for me.
