I have an area on our website that is a repository of a number of pdf files. I would like to be able to open these files from links within separate WebHelp projects.
I can do this by using an absolute reference to the location of the files from within the projects but would prefer to use relative addressing
A simplified structure is
www.mysite.com/pdf for the repository of the pdf files
and
www.mysite.com/project for the location of a project file.
If I use a link in the project containing an absolute reference of the form www.mysite.com/pdf/file.pdf that will work properly
If I attempt to specify the link as ../pdf/file.pdf, it will not work and ends up as www.mysite.com/project/pdf/file.pdf.
Am I using the wrong syntax, or is this just not supported?
Hi David
Earlier you said that if you used ../pdf/file.pdf it failed and ended up as www.mysite.com/project/pdf/file.pdf.
Have you tried using ../../pdf/file.pdf? Given your situation and what you are seeing, that's what I would try.
Cheers... Rick
RoboHelp HTML or RoboHelp for Word?
WebHelp...
Yes but are you using RoboHelp for Word to produce the webhelp or have you now moved to RoboHelp HTML?
Well the project started life in RH for Word, but is now handled under RoboHelp HTML so the question relates to the HTML (WebHelp) project
All that matters is where it is now.
It should be as simple as selecting the text for the link and then clicking the hyperlink icon. There enter the relative path as it will be from where the help is published.
Rh will whinge that the link is external. Just OK that.
If that is not working, please set out the exact steps you are following to create the link.
The issue is the relative path. I can't find a syntax that works.
I select the text, insert hyperlink, link to: web address. Then at that point the web address I enter seems to work only as an absolute address - www.mysite.com/pdf/file.pdf in my example.
Hi David
Cheers... Rick
Yep - that was the syntax I was looking for. As Peter said, RH fussed a little but it worked
Thanks Rick and Peter
