I am using RoboHelp HTML 10 to update a reference project with about 1,500 topics. Is there a way to search the TOC to discover if a specific topic file was added to the TOC by someone before me?
Hi there
Try looking at your Topic List pod. In that pod is a column that will indicate whether the topic has been added to a TOC and it will tell you which TOC it has been associated with.
Cheers... Rick
To add to Rick's response, you can right click inside the TOC and select the Find Topic menu item. This allows you to search for a topic. If the topic is found, it takes you to the TOC location where the topic resides.
We heard you first time, you posted your question three times.
I have deleted two of the posts.
You can only mark one answer as correct.
