I had previous versions of Flash Player and there was no problem. I have no problem downloading and when I install the application I'm told that the installation was successful. Here is the problem:
1. I cannot find the program anywhere on my hard drive when I conduct a file/folder search.
2. My browser is Firefox v 19.1 with the following plugins and extensions:
Browser 1.6.8.0;ADBlock Plus; Do Not Track Me;IEView
3. I have Java enabled
Is there something that I am doing wrong or not doing that prevents Flash Player from effectively installing?
Would sure appreciate any suggestions or input.
Mary
Hi Mary,
Can you go to the "about:plugins" page in Firefox's address bar and past the contents into a reply?
Chris
Thanks for the response Chris,
Here is the contents of about:plugins:
Find more information about browser plugins at mozilla.org.
Find updates for installed plugins at mozilla.com/plugincheck.
Help for installing plugins is available from plugindoc.mozdev.org.
application/x-shockwave-flash | Adobe Flash movie | swf |
application/futuresplash | FutureSplash movie | spl |
application/pdf | Acrobat Portable Document Format | |
application/vnd.fdf |
application/couponsinc-printer-plugin | Coupons, Inc. Gecko Print Manager | |
application/couponsinc-printer-plugin-v404 | Coupons, Inc. FireFox 3.x Print Manager |
application/x-silverlight | npctrl | scr |
application/x-silverlight-2 |
application/asx | Media Files | * |
video/x-ms-asf-plugin | Media Files | * |
application/x-mplayer2 | Media Files | * |
video/x-ms-asf | Media Files | asf,asx,* |
video/x-ms-wm | Media Files | wm,* |
audio/x-ms-wma | Media Files | wma,* |
audio/x-ms-wax | Media Files | wax,* |
video/x-ms-wmv | Media Files | wmv,* |
video/x-ms-wvx | Media Files | wvx,* |
application/WGA-plugin | npLegitCheckPlugin | * |
Hi Mary,
Firefox reports that Flash Player (reported as Shockwave Flash) is installed at C:\WINDOWS\system32\Macromed\Flash\NPSWF32_11_6_602_171.dll.
Are you having problems viewing Flash content? If so, try disabling your browser add-ons and try again.
Chris
Chris,
I found the .dll where you indicated it was located. The odd thing is that whenever I try to open a video with Flash Player a popup tells me that I need to download and install Flash Player?
I will try disabling all my plugins and extensions and search for a video using Flash Player and get back with result.
Mary
I am more confused than ever - I have disabled all active plugins and whenever a web site requires flash player I get a popup window asking me to download the latest version of Adoble Flash Player 34 bit.
I am at a loss now - so many web sites are dependant on Flash Player and no apparent alternative exists!
Mary
When disabling your active plugins, did you also disable the Shockwave Flash plugin? If so, please re-enable it to see if that helps.
Yes Chris, I had disabled Shockwave Flash 11.6.602.171 and Shockwave for Director
10.11.16.
Will enable and see if this helps - will get back.
I sincerley appreciate your interest and patience in the quest for resolution.
Mary
