I have the updated version of Flash player. However I still get pauses in the video and audio. What's wrong.
To help troubleshoot we'll need the following system information:
When reporting issues with video or audio, it's also helpful to get your system hardware and driver details. Instructions for finding this information can be found here:
Finally, sometimes video and audio problems are caused at a lower level and not directly related to Flash Player. I recommend trying both of the links below to see how they perform. If the problem exists with both, then Flash Player is most likely not the culprit as the HTML5 video link does not use Flash Player when playing. You can verify the user of HTML5 by right clicking the HTML5 video and looking for the words "About HTML5" at the bottom of the context menu.
Chris
I'll try your suggestion and get back to you.
Thanks.
Bothe links worked fine
Info requested.
OS X 10.8.2
Flash player version 11.
Did you get pauses when playing back video in the YouTube links? What videos are you seeing this occur with? Many times pauses occur as video is being "buffered" from the server. The amount of buffering that takes place can be dependent on your network speed. Do you know what your speed is when connecting to the net?
