2 Replies Latest reply: Mar 7, 2013 5:10 PM by greenant_qap RSS
    Adobe Flash Player 11.4 installation via SCCM(Batch File)
    harsh5094 Community Member
      Hi Guys,
      I need to install Adobe Flash Player 11.4 on 150+ Computers via SCCM
      I am trying to run batch file in SCCM but doesn't work.
      It says Program has started in reporting but nothing happens and eventually failed saying -> run time exceeded
      SCCM program-> i m just calling ->
      commandline --> flashinstall.bat
      my code in batch file is,
      @echo off
      start \\sms01\source$\Adobe Flash Player 11.4.402.265\IE\flashplayer_11_ax_debug.exe /silent
      start \\sms01\source$\Adobe Flash Player 11.4.402.265\Other Browser\flashplayer_11_plugin_debug.exe /silent
      xcopy /y /q /s "\\sms01\source$\Adobe Flash Player 11.4.402.265\mms.cfg" "C:\windows\System32\macromed\flash\"
      EXIT
      Can you please help me out regarding how to run batch file in sccm
        • 1. Re: Adobe Flash Player 11.4 installation via SCCM(Batch File)
          GuillyAU Community Member
          OK , I just deployed flash player here and it ran like a charmy .
          1 - Download the last version of flash ( msi )
          - Go to this URL and Download the msi file : http://www.adobe.com/au/products/flashplayer/distribution3.html
          2 - Create a "install.cmd" file  .
             - Create a folder , place the flash player msi file there ( install_flash_player_11_plugin.msi) . Inside this folder , create a file with the name "install.cmd" . Open this file and add the follow lines  :
          msiexec /qn /norestart /i "%~dp0install_flash_player_11_plugin.msi"
          exit /B %EXIT_CODE%
          Salve and close the file .
          I assume that you know how to create a package  / program .
          3 - Create a new package
             - After create the packge , create a new program for the package . In command line field , click in browse , make sure that you list "all files (*.*)" and click at install.cmd . Select the msi file (install_flash_player_11_plugin.msi) on "Windows Installer" option  . also , make sure that "Run with administrative rights" is selected on "Environment" .
          Thats  should be enough , let me know how it go .
          Cheers ,
          • 2. Re: Adobe Flash Player 11.4 installation via SCCM(Batch File)
            greenant_qap Community Member
            Hi harsh5094,
            Did you ever get this working. I am looking for the same thing.
            GuillyAU gives me some ideas, but still does not do exactly what you asked.
            I would like a single command or batch file that will install both the Active X and Plugin versions of Flash Player (exe or msi - whichever works best), and also copy the mms.cfg file to the destination PCs (If not already there).
            I was also going to copy the mms.cfg file to both 32-bit and 64-bit directories, instead of just the 32-bit one you mentioned in the OP.
            Currently I have a separate Package for the Plugin and Active X installers, and deploy the mms.cfg file through GPO.
            It would be good to have it all install in the single package.
            I could possible even include AIR and Shockwave in the same script.
