Show 1 reply
1. Re: Workflow from marker to tags in mp3 for audioplayer
SteveG(AudioMasters) Mar 9, 2013 10:05 AM (in response to adob1948)You're going to be a bit stuffed, I'm afraid. MP3 as a format doesn't support markers in its metadata at all. If you want to have markers in audio, then currently the only easy solution is to use the wav format - which supports markers as an appendage to the audio file, and that's what Audition does.
If you want to do something similar for MP3 files, then the only way that I'm aware of is to present each section as a separate file, probably in a numbered sequence.
