Learn about Edge Delivery Services in upcoming GEM session
Email submit
Avatar
Former Community Member
Hi all,
I am trying to create a submit button that will tell the user,thank you for submitting the form and please click send on the default mail client.I added the message but now I am not sure how to add a javascript that will open the open the email and attach the form.
Thanks!!!!
1 Reply
Avatar
Level 5
You could use the following. You could use field entries, then you have to change the path and the objectname to yours.
var Mailto = Formular1.s1.email.rawValue;
You could use static text
var Mailto = "test@test.de";
It's your choice.
if(xfa.host.messageBox("This will be send your PDF.","Information",2,2)==4){
//fill in e-mail
//var Mailto = "test@test.de";
//fill in subject
var Betreff = Formular1.s1.betreff.rawValue;
//var Betreff = "Test-Betreff";
//fill in message
var Nachricht = "Content PDF:\r" + "Field content: " + Formular1.s1.inhalt.rawValue + "\rName: "
+ Formular1.s1.name.rawValue + "\rDatum: " + Formular1.s1.datum.formattedValue;
//var Nachricht = "This is a test message.\r2.row start here.\r3.row here.";
//fill in e-mail cc
var CC = Formular1.s1.emailcc.rawValue;
//var CC = "testcc@test.de";
//fill in e-mail bcc
var BCC = Formular1.s1.emailbcc.rawValue;
//var BCC = "testbcc@test.de";
var Mail = "mailto:" + Mailto + "?Subject=" + Betreff + "&Body=" + Nachricht + "&cc=" + CC + "&bcc=" + BCC;
//cSubmitAs: "PDF" send the pdf as attachment
//cSubmitAs: "XML" send the pdf as xml-attachment
event.target.submitForm({
cURL: Mail,
bEmpty: true,
cSubmitAs: "XML"
}else{}
I hope that will helps?
Mandy
