1. Re: turn a (small) layer into a brush?
conroy Mar 11, 2013 6:17 AM (in response to Mattmcquiff)Mattmcquiff wrote:
I found the clone pattern but in the way I am using it, it doesn't work as I can't see is what my brush is to get it to line up.
Try the Clone Stamp Tool instead of Pattern Stamp Tool. It has a panel (accessed via little button in Options bar - see first image) with options such as an overlay of the pixels that'll be placed by its brush so you can precisely line things up.
2. Re: turn a (small) layer into a brush?
c.pfaffenbichler Mar 11, 2013 6:30 AM (in response to Mattmcquiff)I would recommend using an Action (or better yet a Script) that places the image (File > Place) (edited) and maybe aligns it.
3. Re: turn a (small) layer into a brush?
Mattmcquiff Mar 11, 2013 6:36 AM (in response to conroy)Thats certainly more like what I need the end result to look like, but still means I need to load the image and clone from it.
A colour brush is kind of what I need? (they are always monotoned brushes are they not?)
4. Re: turn a (small) layer into a brush?
c.pfaffenbichler Mar 11, 2013 6:41 AM (in response to Mattmcquiff)A colour brush is kind of what I need?
At current that is not an option in Photoshop.
There are work-arounds, for example you could define a Pattern of the element (preferably with plenty of empty space around it).
5. Re: turn a (small) layer into a brush?
c.pfaffenbichler Mar 11, 2013 6:46 AM (in response to Mattmcquiff)But like I said I think a Script (or Action) would be more convenient.
If the image remains at a fixed position placing it and aligning it (to a certain corner of the receiving image for example) could be automated thus.
6. Re: turn a (small) layer into a brush?
Mattmcquiff Mar 11, 2013 6:58 AM (in response to c.pfaffenbichler)That makes sense although I can't see what the brush/pattern is until i use it is there an overlay like mentioned before?
Script wouldn't work as it is never is in the same place, although maybe to open image sample the clone tool then back to image so that the overlay works.
7. Re: turn a (small) layer into a brush?
c.pfaffenbichler Mar 11, 2013 7:31 AM (in response to Mattmcquiff) -
8. Re: turn a (small) layer into a brush?
Mattmcquiff Mar 12, 2013 6:26 AM (in response to c.pfaffenbichler)When I do the pattern fill
I'm sure I do go about the wrong but how do I turn it into a normal layer? at the moment I 'm sure I take the long winded way and I convert to smart object and then Rasterize the layer.
By the way thanks for your help so far as it is almost working for me!
9. Re: turn a (small) layer into a brush?
c.pfaffenbichler Mar 12, 2013 6:29 AM (in response to Mattmcquiff)The Pattern looks empty.
Could you post a screenshot with the Layers Panel of the file in which you defined the Pattern?
10. Re: turn a (small) layer into a brush?
Mattmcquiff Mar 12, 2013 6:37 AM (in response to Mattmcquiff)not empty I just put lots of space around it the pattern is from a repeating pattern of 3744 x 5616, so its there, I was attempting to turn it into a script but when I do the Rasterize layer I get an error
- The command “Rasterize” is not currently available.
Line: 68
-> executeAction(cTID('Rstr'), desc1, dialogMode);
#target photoshop
// SilverStud.jsx
// Generated Tue Mar 12 2013 13:19:33 GMT-0000
cTID = function(s) { return app.charIDToTypeID(s); };
sTID = function(s) { return app.stringIDToTypeID(s); };
//==================== Silver Stud ==============
function SilverStud() {
// Select
function step1(enabled, withDialog) {
if (enabled != undefined && !enabled)
return;
var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
var desc1 = new ActionDescriptor();
var ref1 = new ActionReference();
ref1.putName(cTID('Lyr '), "Main Image");
desc1.putReference(cTID('null'), ref1);
desc1.putBoolean(cTID('MkVs'), false);
executeAction(cTID('slct'), desc1, dialogMode);
// Make
function step2(enabled, withDialog) {
return;
ref1.putClass(sTID("contentLayer"));
var desc2 = new ActionDescriptor();
desc2.putEnumerated(cTID('Clr '), cTID('Clr '), cTID('Rd '));
var desc3 = new ActionDescriptor();
var desc4 = new ActionDescriptor();
desc4.putString(cTID('Nm '), "SilverStud");
desc4.putString(cTID('Idnt'), "87fbf98c-cb9c-1175-9748-b7a0e8073d1f");
desc3.putObject(cTID('Ptrn'), cTID('Ptrn'), desc4);
desc2.putObject(cTID('Type'), sTID("patternLayer"), desc3);
desc1.putObject(cTID('Usng'), sTID("contentLayer"), desc2);
executeAction(cTID('Mk '), desc1, dialogMode);
// Convert to Smart Object
function step3(enabled, withDialog) {
return;
executeAction(sTID('newPlacedLayer'), undefined, dialogMode);
// Rasterize
function step4(enabled, withDialog) {
return;
ref1.putEnumerated(cTID('Lyr '), cTID('Ordn'), cTID('Trgt'));
// Move
function step5(enabled, withDialog) {
return;
var ref2 = new ActionReference();
ref2.putIndex(cTID('Lyr '), 2);
desc1.putReference(cTID('T '), ref2);
desc1.putBoolean(cTID('Adjs'), false);
desc1.putInteger(cTID('Vrsn'), 5);
executeAction(cTID('move'), desc1, dialogMode);
step1(); // Select
step2(); // Make
step3(); // Convert to Smart Object
step4(); // Rasterize
step5(); // Move
// SilverStud.main
SilverStud.main = function () {
SilverStud();
SilverStud.main();
// EOF
"SilverStud.jsx"
// EOF
11. Re: turn a (small) layer into a brush?
Yes brush are one color. Have you thought about extracting it and saving it as a PNG-24 with a transparent background and using file Place to get it into other images with and action.
Brushes are one color but can have different levels of opacity like this one.
12. Re: turn a (small) layer into a brush?
Mattmcquiff Mar 12, 2013 8:23 AM (in response to JJMack)Actually all I have done now is use the regular fill pattern on a new layer and save is as an action.
Many Thanks for your help.
