1. Re: Will NIK plugin software work with PS in Creative Cloud?
David__B Mar 12, 2013 3:55 PM (in response to berniedog12)Hi Berniedog12,
Most likely, the Creative Cloud version of Photoshop CS6 is the same except additional features
http://www.niksoftware.com/support/usa/entry.php?view=system_requirements_compatibility
-Dave
2. Re: Will NIK plugin software work with PS in Creative Cloud?
Noel Carboni Mar 12, 2013 6:32 PM (in response to berniedog12)I imagine so, as the plug-in interface of Photoshop is still as it was, but don't we really have to ask the Nik people that question to be sure?
It's up to them to make their plug-ins compatible with the latest version of Photoshop.
If they say they're compatible with Photoshop 13.1.2 then your question is answered "yes".
-Noel
3. Re: Will NIK plugin software work with PS in Creative Cloud?
SandraChung Jun 20, 2013 4:39 PM (in response to berniedog12)Actually, at this time the answer is no, they won't work with Creative Cloud. If you start the installation file for any of the Nik plugins, Creative Cloud isn't recognized as a compatible software. Even copying and pasting the plugins from CS6 directory doesn't work, as CC scans the plug in directory and doesn't recognize the plugins.
4. Re: Will NIK plugin software work with PS in Creative Cloud?
Graham in NC Jun 20, 2013 6:05 PM (in response to SandraChung)There's numorous threads concerning NIK plugins and PS CC; I've posted to several.
Copying my Google (NIK) folder from the PS CS6 plugin directory to the PS CC plugin directory works. I have full use of NIK plugins in PS CC.
One may also use the Google installer, and select the "plus" sign at the bottom to manually add the PS CC plugin directory to the install location.
If my copy of PS CC works with NIK, then it stands to reason if your copy isn't working, you've done something wrong. There's no incompatability with NIK plugins and PS CC.
Insure your shortcut to PS CC points to the correct version (and the version where you've loaded the NIK plugins) e.g., if you've loaded the plugin folder to the 64 bit version, make sure that's the program shortcut you're selecting.
Graham
5. Re: Will NIK plugin software work with PS in Creative Cloud?
SandraChung Jun 20, 2013 7:16 PM (in response to Graham in NC)Yes, turns out I had to re-download the file I was given link to. Have no idea why the full installer didn't work the first time, but it did the 2nd time.
But still, too many other plugins also don't work, and even though I don't rely on them for all photo processing, they are part of my workflow. And without them working, or more like only 1/4 of them working, CC isn't an option for me. I'll stay with CS6E
6. Re: Will NIK plugin software work with PS in Creative Cloud?
MLB - Reno Sep 19, 2013 2:31 PM (in response to berniedog12)Following Graham's advice worked perfectly for me. It was easy and straightforward. I had tried to instal the NIK suite directly into Photoshop CC by hitting the + key and selectly the Plug in Folder of Photoshop CC using the NIK installation program. This did not work, but copying the NIK Suite from the Plug-in folder in Photoshop CS6 and pasting it in the Plug-in Folder of Photoshop CC was easy and IT WORKS, at least for me.
7. Re: Will NIK plugin software work with PS in Creative Cloud?
Michael D Sullivan Sep 20, 2013 8:08 PM (in response to Graham in NC)The approach of using the plus sign in the Nik installer worked for me.
8. Re: Will NIK plugin software work with PS in Creative Cloud?
Seemak Dec 19, 2013 9:24 AM (in response to Graham in NC)My NIK software worked fine from the first moment i used PS CC. Now after a couple of months PS CC doesn´t start anymore at all. It crashes with the message "Photoshop CC can not be initialised due to a programe failure". The message is not helpful at all. So i did contact tech support. Advice from tech support: "We do not support any plugin officially" De-Install NIK otherwise we can not help you at all ". Thanks to tech support. Like always the customer is being pushed around betwee both SW Vendors. I wil go back to CS5 and NIK and quit my contract with PS CC asap. Saves money and i can work. No i pay money for something useless if it doesn´t support any plugin. I can understand Adobe...as it is the best way to make money if i buy everything from them. But there are programs in the market which can do specific things better. So i can not understand the ignorance of these tools. We as a professional designer, photographer want to achieve the best result and want to be free in the usage of the tools we use to achieve this. The current strategy of Adobe with plugins is not good for the user / customer. Somebody should re-think about it.
9. Re: Will NIK plugin software work with PS in Creative Cloud?
Noel Carboni Dec 19, 2013 1:44 PM (in response to Seemak)Now that you have that out of your system, Seemak, would you like to try to get to the bottom of what's going wrong?
Assuming you have Windows, look in your Application Event Log and dig out the additional information there. Perhaps something there will give us an idea of what's failing.
If you're on a Mac, I'm sure there are Mac experts who might be willing to help you.
-Noel
10. Re: Will NIK plugin software work with PS in Creative Cloud?
Hawklord Jun 20, 2014 1:31 PM (in response to MLB - Reno)It worked for me as well. Thanks.
11. Re: Will NIK plugin software work with PS in Creative Cloud?
Aussieroo Jul 29, 2014 12:26 AM (in response to Hawklord)Copying from a previous install on CS6 worked for me as well. Thanks Guys.
