2 Replies Latest reply: Mar 13, 2013 3:05 AM by Israelus RSS
    With the last update... I have a problem in a accordion widget
    Israelus Community Member
      My site had a too many accordions widgets, that works fine, but with the last feature, now I have a space between the accordion widget and the rest of the page.
      ¿why?
      And... Is there any way to resolve this faster?
      thanks
        • 1. Re: With the last update... I have a problem in a accordion widget
          Vinayak_Gupta Employee Hosts
          Try a Select All on page in Design mode and see if you don't have any transparent object placed between the Accordion and the footer. Also try re-inserting the Accordion panel and preview the page in browser, see if that helps. Toggle between the Sticky footer option to check if that makes any difference. If this happened since the update, make sure you upload All Files (and not just modified).
          If the problem persists, the site URL would help!
          Vinayak
          • 2. Re: With the last update... I have a problem in a accordion widget
            nothing. I tried everything you name, but nothing.
            The principal problem is that the line-guide-header on master page, now is displaced to down all the top of the menu bar (accordion widget) as being opened. So I see the space between the bar and the other elements. And before the last update was ok.
            The only thing that works is up the lin-guide-header on master page, but other thing that happened now is that the menu-bar (accordion widget) after move the line-guide-header not appear in the thumbnails on Plan view.
            ahhhhhhhhhhh why?
            I´ve readed in other post that is a bug.
