Hello,
does exist a documentation about the contents of the FlashPlayer installation log file "flashinstall.log"?
It could be interesting to understand the entries. Additionally the documentation of the error codes could help to find and fix installation/update problems...
'til now, I haven't found any documentation about on Adobe pages. I found, how I can activate/deactivate logging, but nothing about the structure, the meanings, error codes, etc....
Best Regards
Axel
There is no published info that I know of. Are there particular entries that you are curious about?
Thank you for your answer Chris.
I'm interested in the general structure of this log, to understand in a better way, what's happen.
What do the the different entries in the brackets mean, for example
0006
0007 ...
0008
I'm interested in a list of the different error codes, for example the following one: (I've a lot of more, but this error appeard mostly in the logs, independent of a working FlashPlayer or not...)
[error] 1223 1058
Next info about the different parameters (?) of EXE, DLL or OCX entries which appear sometimes or not
C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe 5
C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_135.ocx 5
What do the numbers mean after the brackets, they are not continuous
0000 00000010
0001 00000020
0002
0003 00000018
Why and how is it possible, that I can find a user profile path entry of an Flash-update in the log, no user has rights to install applications in our environment.
Normally updates should be installed by local system (automatic) or admin...
etc.
I don't understand, why there exist no documentation about. There exist in several documents the hint, how to activate logging, but nowhere a description about the logs...
Best regards
Axel
Maybe Chris can provide more info, but the code in the brackets mean
= Information (correct)
The numbers at the end of a file (5, 183) indicate that the file could not be written or replaced (permission issue).
I have never been able to figure out what the numbers after the bracketed code mean.
Thank you Pat for the hints...
It's interesting, if you receive a warning in the log without a hint about the problem... 🙂
I found this in a log, without any information behind the numbers or is it caused by the last entry?
=O====== M/11.5.502.146 2013-01-23+15-12-36.708 ========
0000 00000010 "C:\Program Files\LANDesk\LDClient\sdmcache\install_flash_player_ax_32bit_11.5.502.146.exe" -install
0001 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0002 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash32_11_5_502_146.ocx
0003 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
0004 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.dll
0005 00000023 C:\WINDOWS\system32\Macromed\Flash\activex.vch
0006 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0007
0008
0009 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0010
0011
0012
=X====== M/11.5.502.146 2013-01-23+15-12-43.318 ========
FlashPlayer was installed with success and running! But 'til this day, the log entries are changed in this way:
2013-1-23+15-20-1.453 [error] 1223 1058
2013-1-24+12-20-15.250 [error] 1223 1058
2013-1-24+13-20-15.93 [error] 1223 1058
2013-1-24+14-20-15.93 [error] 1223 1058
2013-1-24+15-20-15.93 [error] 1223 1058
2013-1-24+16-20-15.109 [error] 1223 1058
2013-1-25+7-20-15.484 [error] 1223 1058
2013-1-25+8-20-0.261 [error] 1223 1058
2013-1-25+9-20-0.432 [error] 1223 1058
2013-1-25+10-20-0.248 [error] 1223 1058
2013-1-25+11-20-0.459 [error] 1223 1058
2013-1-25+12-20-0.584 [error] 1223 1058
2013-1-25+13-20-0.443 [error] 1223 1058
2013-1-25+14-20-0.257 [error] 1223 1058
2013-1-25+15-20-0.501 [error] 1223 1058
2013-1-28+8-20-15.671 [error] 1223 1058
2013-1-28+9-20-15.78 [error] 1223 1058
2013-3-12+12-20-15.93 [error] 1223 1058
2013-3-12+13-20-0.109 [error] 1223 1058
2013-3-12+14-20-0.62 [error] 1223 1058
2013-3-13+9-20-15.578 [error] 1223 1058
Client was offline a while, so no newer update was installed 🙂 but I will soon, if I understand the error messages...
Regards
Axel
