Show 5 replies
1. Re: Be careful of IE7 updates
Newsgroup_User Jan 17, 2007 10:20 AM (in response to David Stover)Actxiom wrote:
> I pulled up a set of files to update them and was greeted by "This page
> contains <object tages> that may not work properly in the most recent versions
> of IE. To correct the problem you can convert to browser safe scripts. Do you
> want DW to convert these?" I chose yes and then none of the Flash Headers
> worked.
> Has anyone else experienced this? Do I have the cause and effect right here?
what DW forgot to tell you is that it created an external js file, probably placed in a folder
called "scripts" or somewhere else, and that you have to upload that folder/file to your server.
seb ( ---@webtrans1.com)
http://webtrans1.com | high-end web design
Downloads: Slide Show, Directory Browser, Mailing List -
2. Re: Be careful of IE7 updates
Newsgroup_User Jan 17, 2007 10:23 AM (in response to David Stover)I've gotten it a lot since I updated Dreaweaver 8 with the latest patch.
I beleive the latest update nicludes a javascript to defeat a recent
active-x activation routine in IE
I don't know if it revolves around IE7, I assumed something different.
An update to IE6 at some point made the user "activate" an active-x object,
such as a Flash movie.
So if you had a Flash movie with a link on it, you would have to click once
over the movie to activate it as an active-x object, then you were clear to
click on the movie.
I could be wrong in the real reasoning behind it, but I have experienced it,
and that seems to be the scoop for what I've experienced.
-Dave
"Actxiom" <webforumsuser@macromedia.com> wrote in message
news:eolp8s$c4c$1@forums.macromedia.com...
> versions
> you
> worked.
> here?
3. Re: Be careful of IE7 updates
Newsgroup_User Jan 17, 2007 10:33 AM (in response to David Stover)It's IE-only behaviour as a result of changes Microsoft made earlier this
year to their browser, regarding how Active Content (Flash, Quicktime etc)
is handled, after losing a high profile court case.
http://blog.deconcept.com/2005/12/15/internet-explorer-eolas-changes-and-the-flash-plugin/
Background:
http://en.wikipedia.org/wiki/Eolas
See also
http://www.adobe.com/devnet/activecontent/
If you're running Dreamweaver 8.0.2, the fix is already built into DW's
interface.
If not, try http://blog.deconcept.com/swfobject/
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.dreamweavermx-templates.com - Template Triage!
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
"Dave Bar" <d@d.com> wrote in message
news:eolpij$cic$1@forums.macromedia.com...
> object, such as a Flash movie.
> once over the movie to activate it as an active-x object, then you were
> clear to click on the movie.
> it, and that seems to be the scoop for what I've experienced.
> -Dave
>> versions
>> you
>> worked.
>> here?
4. Re: Be careful of IE7 updates
David Stover Jan 17, 2007 11:03 AM (in response to Newsgroup_User)Thanks for the comments from the last two responders. That is all I need to reply to my web page designer to confirm why I screwed up our site.
Actxiom (Dave) -
5. Re: Be careful of IE7 updates
Newsgroup_User Jan 17, 2007 11:07 AM (in response to Newsgroup_User)Actxiom wrote:
> Actxiom (Dave)
just upload the script!
