Hi, all:
I admit first of all that my source document is far from pristine, has many styles from many authors and came from many source documents. I also admit that despite using RH since 1995, linking documents didn't come easily to me...now that I am seemingly over that hurdle, new challenges await...
In my WebHelp project I have a master page pointed at my modified .css, which is in a subfolder with my linked topics.
I have assigned H1, H2 and H3 headings as Tahoma 18 pt. and have defined my"normal" as Tahoma 12 pt. Normal looks like Tahoma 12 pt in the Styles and Formatting pod when the selected topic has the .css assigned to it.
I have run several tests:
Test I: Topics with no master page and no .css selected in the Appearance tab.
Result: All Times New Roman for both Header and Normal (expected)
Test II: Topics with no master page but with same modified .css selected in the Appearance tab.
Result: Tahoma 18 pt Header (expected), but Times New Roman for Normal (not expected)
Test III: Topics with master page but no .css selected in the Appearance tab.
Result: All Times New Roman for both Header and Normal (not expected)
Test IV: Topics with master file and with same modified .css selected in the Appearance tab.
I have many other crazy styles that came in when I linked the document, but if I could just understand why "normal" doesn't display the font I edited in my .css file, then I think I can connect the dots for the rest.
Thanks and regards,
Tracy
Hi Tracy.
Test III does give the expected results. Despite there being a master page assigned, you can override the CSS. So if there is no CSS applied the default font (Times New Roman) is applied.
As for the other non-expected tests, you'll need to do a bit of detective work. The problem could be one of two things.
One way to find out what is going on is to roll up your sleeves and jump into the HTML. Perhaps you can post an example here of what you see for one of the errant styles.
Hi, RC
Sorry for late response, I had a family emergency on Thurs. I will do some research and will follow up shortly.
Thank you,
Trace
Tracy
Have you seen the pages on my site about Linking?
Hi, Peter:
I have looked at some of your content, but will take a deep dive today. Thanks for your continued support. I REALLY need to resolve this a.s.a.p.
Trace
P.S.: When I performed "Removing any inline formatting and applying proper styles will help. To remove all inline formatting from a Word document, press CTRL A to select all the text and then press the spacebar." ...it reduced the contents of the ENTIRE 252-page document to two show/hide symbols...
Hi, gentlemen:
I ran through the tutorials and I what I am seeing is this:
Either my real source document is fundamentally flawed, or I somehow missed a step and broke my project forever.
I am now heading back to give my ugly source document another go. Fingers are crossed!
Thanks all!
P.S.: IF essentially ALL topics in my source document have inline styles, is any of this possible?
The instructions for removing the inline formatting should have read CTRL and spacebar. I have amended that. Amazed no one else has reported that.
THAT DID IT! It was the inline formatting that was locking everything up! I just ran a quick test and the topics now look as I expected them to.
Thanks so very much to you and Mr. RoboColum(n)!!!!!
