Locked
Keywords and description are not showing up
Mar 09, 2013 Mar 09, 2013
Why don't my key words show up when I veiw page source in Safari?  I'm setting them in muse by going to page, page properties, Metadata and filling in the description and keywords.  My site address is www.maltbylakeskennel.com
Thanks for any help.
dom
Newbie Corner
990
Adobe Employee ,
Mar 10, 2013 Mar 10, 2013
Hi Dom,
Please check if you are able to view them correctly here http://maltbylakeskennel.businesscatalyst.com/.
If yes, please correct the domain settings. It is not clear if you would like to use 'This Service' or 'External' as your domain is not pointing to BC at all.
Thus, not resulting the correct page with the changes made.
Please check this for more help on using BC DNS service  -> http://kb.worldsecuresystems.com/kb/change-domain-name-site.html
If you want to use external DNS service for your domain name check this -> http://kb.worldsecuresystems.com/157/bc_157.html
Hope that helps!
Mar 11, 2013 Mar 11, 2013
Actual issue is he is using iframes.
iFrames gallore and only one frame pointing to BC. There are also development urls in there in the mix as well.
Since the parent frame is the main frame of the site and this is not BC and has not much of anything this is what search engines see (nothing) and because it is not BC you have no meta there.
This is the problem (along with many others) in using iframes and If you would like to use BC properly, I am not sure how you have built the site but you want to ditch the iframes and use BC fully.
Then as TS-Rohit has mentioned you set up the domain properly.
Hi Liam and TS-Rohit thank you for the reply.
Yes both www.maltbylakeskennel.com and http://maltbylakeskennel.businesscatalyst.com both
view correctly.  I am using BC and I created the site in Adobe Muse 4.0.
For some reason I just can't get the pointing to setting straight in my
head, here are the settings.  Can you let me know what needs to be changed?
Name                                                          Start Page/Domain Forwarding                             Country                  DNS
www.maltbylakeskennel.com                                 Forwards To - maltbylakeskennel.businesscatalyst.com                                        This Service
www.maltbylakeskennel.com (default URL)                          Start Page - Home Page                                              US                 This Service
maltbylakeskennel.worldsecuresystems.com (secure)               Start Page - Home Page                                              US                 This Service
maltbylakeskennel.com.maltbylakeskennel.com           Forwards To - maltbylakeskennel.businesscatalyst.com                                   External
maltbylakeskennel.businesscatalyst.com (system)                     Start Page - Home Page                                             US                 This Service
Thanks again for the help
dom...
Adobe Employee ,
Hi Dom,
If you are planning to use BC DNS service, I would suggest to delete all the records by clicking on 'Delete' and then 'Yes Delete all' records. Try to add the domain again using New Domain -> Add as maltbylakeskennel.com , Set a Start page , Using this service,  and this will automatically create the records to point correctly to the Start Page.
You will need to replace any existing nameservers at you registrar to :
  • ns1.worldsecuresystems.com
  • ns2.worldsecuresystems.com
  • ns3.worldsecuresystems.com
As explained here -> http://kb.worldsecuresystems.com/kb/change-domain-name-site.html
If you face any issues further, kindly contact support via http://helpx.adobe.com/contact.html on chat or raise a ticket.
We will be happy to assist you further.
Kind Regards,
Again though, that is only one problem. The iFrames are another issue as mentioned.
Thanks for all the info I'll start on that later on tonight. What are
iFrames? I created this in Adobe Muse, does Muse use IFrames?
Thanks again.
dom...
Frames of content, you have several.
http://whatis.techtarget.com/definition/IFrame-Inline-Frame
Muse does not build those by default so I am not sure how they are there.
That is strange all pages were made with Muse only.
dom...
Mar 14, 2013 Mar 14, 2013
OK I have everything working and showing up the way it should. All I did
was rename the nameservers at my registrar to the ones you told me to and
that seems to have done it.
Everyone, thank you for all the help.
dom...
