4 Replies Latest reply: Mar 17, 2013 1:05 PM by BKBK RSS
    Binding Form Elements to Query Data
    bfleishman Community Member
      Hello,
      I have a simple form thatI'm binding query data to so I can populates a cselect box and, based on the selection, populate cfinput boxes. I have the code for this form in a <cfinclude template> and it is working just as designed.
      But strangely enough, if I wrap the <cfinclude> code that contains my form in <cfdiv> tags, the binding breaks.
      What would be causing that? Any help would be super greatly appreciated.
      -Brian
      Main Page Code with form:
      <cfajaximport tags="cfform,cfdiv">
        <cfdiv>
           <cfinclude template="vehiclelog.cfm">
        </cfdiv>
      CFInclude File:
      <cfform name="addmileage" method="post" action="actionpages/addmileage.cfm">
               <table cellpadding="10">
               <tr><td>
                <fieldset>
                <legend>
                <img src="images/service_vehicle.png" alt="Vehicle Log" /> <strong>Vehicle Log </strong> </legend>
                <table width="100%" border="0" cellpadding="5">
                        <tr>
                          <td><label>Service Vehicle:</label></td>
                          <td><cfselect queryPosition="below" name="vehicle_name" id="vehicle_name" value="vehicle_name" bind="cfc:cfcs.mileagedata.getData()" bindonload="true" >
                          </cfselect>                    </td>
                        </tr>
                        <tr>
                          <td>Origin:<br />
                            <label></label></td>
                          <td><cfinput name="origin" type="text" /></td>
                        </tr>
                        <tr>
                          <td>Destination:</td>
                          <td><cfinput name="destination" type="text" /></td>
                        </tr>
                        <tr>
                          <td><label>Start Odometer:</label></td>
                          <td><cfinput onFocus="startOdometerCalc();" name="start_odometer" type="text" bind="cfc:cfcs.mileagedata.getDetail({vehicle_name})" bindattribute="value" bindonload="true"/></td>
                        </tr>
                        <tr>
                          <td>End Odometer:</td>
                          <td><cfinput onFocus="startOdometerCalc();" id="end_odometer" name="end_odometer" type="text"  bind="cfc:cfcs.mileagedata.getDetail({vehicle_name})" bindattribute="value" bindonload="true"/></td>
                        </tr>
                        <tr>
                          <td><label>Total mileage:</label></td>
                          <td><cfinput onFocus="startOdometerCalc();" id="total_mileage" name="total_mileage" type="text" /></td>
                        </tr>
                        <tr>
                          <td><label>Expenses:</label></td>
                          <td><cfinput value="0.00" name="expenses" type="text" /></td>
                        </tr>
                        <tr>
                          <td><cfinput type="submit" name="submit" id="submit" value="Submit" /></td>
                          <td> </td>
                        </tr>
                      </table>
                </fieldset>
                </td></tr></table></cfform>
      CFCS
      <!---Service Vehicle Slect Box --->
      <cffunction name="getData" access="remote" returntype="query">
          <cfoutput>
          <!--- Function to get data from datasource --->
          <!---Get Service Vehicles --->
          <cfquery name="data" datasource="#datasource#">
          select vehicle_name
          from vehicles
          where active = '1'
          </cfquery>
          </cfoutput>
          <!--- Return results --->
          <cfreturn data>
      </cffunction>
      <cffunction name="getDetail" access="remote" returnType="string">
          <cfargument name="vehicle_name" type="any" required="true">
          <!--- localize function variables --->
          <cfset var dataDetail = "">
          <cfoutput>
          <cfquery name="dataDetail" datasource="#datasource#">
              SELECT mileage
              FROM   vehicles
              <!--- adjust cfsqltype if needed --->
              WHERE vehicle_name = <cfqueryparam value="#ARGUMENTS.vehicle_name#" cfsqltype="cf_sql_varchar">
          </cfquery>
                </cfoutput>
          <cfreturn dataDetail.mileage>
      </cffunction></cfcomponent>
