I have a form filed and need to make sure that there is not URL's being passed through it. I would like to search the field and test it for "http" and/or "www", if those charters are present I would like to send it to a special page that handels it and then abort the rest of the script.
Can anyone help me with this?
Nick
See if this helps. It's from my regex cheat sheet.
<cfset regex = "^(http://|www)[a-zA-Z0-9\-\.]+\.[a-zA-Z]{2,3}(/\S*)?$" />
Then :
#refind(regex,"your_string")#
Should return 1 if there's a match, or 0 if there isn't.
Then :
Paul,
You were spot on with your post, I can't thank you enough for your help!
Have the code in place and it is working like a charm.
Nick
Paul,
After a bit more testing I noticed that your regex was not working. I had to use the following code to getthe script to work:
<cfset stringToSearch = '#form.xxx#'>
(Notice, I had to use single quotes instead of double quotes, the double quotes were killing me!)
<p>
<cfset foundit = '#FindNoCase("http",stringToSearch)#'>
<cfif foundit gt 0>
<cflocation url="http://www.xxx.com">
<cfabort>
</cfif>
Had to use:
#refind("http","your_string")#
Instead of:
Have no idea about Regular Expressions, wish I understood what your code is doing so that I could work on it to get it to work but all I know is that the script works this way and I will take it! 🙂
Thanks again for your help!
Nick
Paul,
I wanted to use your code but when I uesed #refind(regex,"your_string")# and tested it it did not catch any of the test data that I used. I used the following code and it worked with all of the test data:
<cfif foundit gt 0>
<cfabort>
</cfif>
It should not matter that I used FindNoCase instead of ReFind?
If I used the following do you think it should have worked?
<cfset foundit = '#FindNoCase(regex,stringToSearch)#'>
<cfif foundit gt 0>
<cfabort>
</cfif>
I liked you code because it also tested for www and that would have been good to test for!
Thanks for all your help!
Nick
Tweaked the regex. It should find a url with or without the http://
<cfset regex = "^(https?:\/\/)?([\da-z\.-]+)\.([a-z\.]{2,6})([\/\w \.-]*)*\/?$" />
<cfset my_search_string = "http://forums.adobe.com/">
<cfset foundit =refind(regex,my_search_string>
<cfif foundit gt 0>
<cfabort>
</cfif>
If you are passing a variable as the second argument in refind(), leave the quotes out. If it's a string, then it needs to be quoted.
Paul,
I will work on it tomorrow and get back to you.
Thanks again!
Nick
